Hi all,
The coating on my wheels has been bubbling and flaking off in places since I've had the car.
It's kinda annoying me so I was wondering if anyone has advice:
1. Ignore and don't worry
2. Get them sand-blasted and powder-coated
3. Other options? Wheel repair/reconditioning places???
Option 2 is probably sensible but - wank factor aside - I'd like to retain the Nismo logos if I can...
If anyone knows of somewhere reliable in Brisbane to get this done, the advice would be appreciated, thanks! :rolleyes: Pics attached.
https://www.sau.com.au/forums/topic/101060-getting-wheels-re-coatedrepaired/
I am relying on a 5 year memory but Chris Neil from Wheel Revolution.
Unit 2/18 Randall St Slacks Creek.
He's the man to see.
I second Chris as well. Yes he' still there and I've used him before. He's even got a write up in the current issue of HPI, go have a read. Depending on the damage repair work starts at around $40 per rim. He has the ability to bring your wheels up to brand new condition...if I had Nismo's I'd definately spend the $$.
Hi all,
If anyone knows of somewhere reliable in Brisbane to get this done, the advice would be appreciated, thanks!  :mellow:  Pics attached.
Hey jamac go with a wheel shop or panel beater, don't get the wheels powder coated just have them painted in enamel (sp?).
They will not build up the dust as quick & r a lot easyer to clean when in enamel...
enamel your joking rite ?? :mellow: I wouldn't paint my dog kennel in it, thats if I had a dog kennel. 2pak or powder coat only
the guy at street art wheels up here at kunda park has been toying with a chrome finish for wheels for a few years now, not sure how he does it but he also does scratch and repair of mag wheels and repaints them in any colour u like. its called
"StreetArt Wheels,
1/ 33 Enterprise St Kunda Park QLD 4556
ph: (07) 5477 0240 Wheels & Rims--Automotive
Edited by 85URK
The HPI article only touched on rim repairing but overall they provide wheel restoration as well which includes painting. I had a set of Volks that had stone chips and gutter rash and all they did was restored it and repainted it in its original color...came out brand spanking new!
lmao go right ahead & spray your wheel in 2pac lmao if u got the $$$$ & powder coat tends to make the brake dust build up of the wheels more done it my self so know about it enamel is easy to fix if u get chips & is not to costly it depends on u if your going to use the wheels on a show car & have the money to get em done in 2pac go for it or if money is a problem go for the powder coat or enamel ....
ever heard of a fullstop dude lmao! :mellow:
For machining, buckles, gutter rash etc: Dean at Depulu in Ashmore
For refinishing, painting and polishing: Dean at Mag Wheel Services in Southport.
I have personally used both these guys on more than one occasion and they are great at what they do. I absolutely swear by these guys!
I also take my wheels to Depulu for balancing, although they don't really do this as a service, they're the only place that seem to be able to get it right and are usually happy to do a balance only job. Also its noteworthy that these guys never use rattle guns.
-rb25
Edited by rb25
2pak is not that much different from enamels price range because enamel is on its way out and going up in price.There lots of cheap 2pak out there thats better then enamel
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
