i wanna put a set in my r32 gts-t mine has a aftermarket cd and climate control and i have had it all apart several times.... what do i need and can i hook the guages up to a std loom at all???? if not what do i have to do any help would be appretiated...thanks guys...... :(
https://www.sau.com.au/forums/topic/10129-gtr-triple-centre-guages-help-me/
Isnt one of the GTR guages a traction meter for the attessa system, surely thats of no use to you anyway?
What are the other 2 guages?
It would be much easier to just buy 3 guages that you want, get a flat piece of ally or plastic, cut 3 holes in it and hey presto your own GTR triple guage that looks better and doesnt have a defunct traction meter.
Red17
  • 3 months later...
The above is correct.
You notice how the GTS climate controls have the bevelled edges?
The GTR ones have the bevelled edges and then there's the square climate controls.
You really need the whole GTR centre guages and aircon controls and loom. In the 33 you have to discard the torque meter.
It really is more work than it's worth. The setup would fill the centre section and you loose the double din obviously.
T.
T.
that is that case in the r33
but the r32 there is no bevelled egde on any of them
so it really depends on the car
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
