Hi guys,
I've had bigger wheels fitted for a while now (stock to 18s) and didnt think anything of it. Anyway during a highway trip I made sure I stuck to around the 110km/h speed limit but my friends who were following me were telling me I was speeding, doing 120 (double demerits), and it hit me that its because of the wheels.
Just want to know if anyone has had their speedos corrected, is this a DIY job? if not who does it in Sydney? Approx cost as well.
Thanks!
https://www.sau.com.au/forums/topic/101291-speedo-correction/
If your tyres are the correct profile they should be the same rolling diameter as the stock tyres and therefore not affect the speedo reading.
If they are oversize I think there is an electronic kit (Jaycar?)that can vary the speed sensor output to correct the speedo.
I could be wrong.
Do a search.
Ok I did a search and picked up a few threads about it. This thread seems to sum it up.
http://www.skylinesaustralia.com/forums/in...wtopic=1461&hl=
Looks like its pretty involved for a DIY job
Has anyone got theirs corrected by a specialist in Sydney?
Maybe your friend's speedo reads over the real speed (which is the usual level of inaccuracy of speedos).
If you have fitted the correct replacement 18" tyres, then the speedo reading should not have varied significantly. Ask the tyre place to show you the manufacturer's specs on the tyres you fitted compared with the tyres you replaced.
I DIY'd in my 180SX and would be happy to help if I can.
Perhaps you could duck in to JustJap and have a look at an R33 cluster and see if it has the trim pot so you can adjust yourself.
With hindsight though, if I faced the same problem again, I would just go and buy the correct profile tyres.
Cheers dude, good luck sorting it
when i bought my nismo 300km/h speedo it was out by half eg when i was doing 60 it would show 120. i bought a digital speedo corrector from jaycar and it did the job. you have to build it yourself but i just took it to an autoelectricain, the only one who could do this as i asked around. if you want pm me and i will give you the details of the guy.
btw im in sydney also.
dave....
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
