Hi,
does anyone know if there are any aftermarket options to replace the stock air bags on a cima?
OR if any other models' suspension can be used to replace the air bags completely?
OR a good wrecker (Other than in SA, tried most already) that have them/can get them?
Ive tried nissan they want $665 each plus two weeks from Japan.
cheers
Aden.
https://www.sau.com.au/forums/topic/101373-y31-cima-air-bag-suspension/
My mate just split the airbags in his Cima
he ended up getting adjustable coil overs custom made to suit for $2200 install
is probably the best option as installing and aftermarket airbag setup will cost over $5000
and second hand parts are likely to fail again
  • 3 weeks later...
Hi,
cheers
Aden.
Ok, after going through the same thing i have some info that can help. Firstly i was quoted $1600 each, plus 2 weeks shipping from Nissan. Dont know who you went through, but can you please give me their number because thats an awesome price for new struts!!
Secondly, I spoke to some airbag suspension places and they told me it would be $700 to get aftermarket airbags put on the OEM struts. Compared to the $1600 that was quite tempting (cos aftermarket bags dont mind being deflated).
Going through the any of the Yahoo Purchasing services was going to cost me about $400, and that was getting closer to my budget.
Finally i rang JustJap in sydney and they managed to get me one front and both rear struts (secondhand) for $250!! Really dont know how they managed that because I cant imagine shipping being so cheap. Only downside was the 8 week wait. But i have them now, and although they look kinda old, they seem to be holding up...
Anyway, as others have mentioned, you might be able to get coilovers for around the $1000+ mark from Yahoo auctions, but they all seem to be the JIC SF-1s and from what i have been told these are a brutally stiff coilover. Plus for me i *need* air sus because my front bar is only 1-2cm off the ground when the car is lowered just right...
If you just need something to get you by, i have been told that R31 skyline (Aus spec) struts fit. Only problem is that the brakes are much smaller, and its 4 stud instead of 5 stud
Another option is Z31 300ZX struts which are also supposed to be plug and play. THe turbo models had 5 stud, and similar brakes, but i believe they are kinda rare...
I have taken out Y31 strut and compared it to a R31 strut and I can say for cartain they DO NOT fit.
The top hat is a different size and the holes dont line up. the brakes are different and the travel distance is 40 mm longer with the R31 strut.
The inserts may however be the same as non airbag Y31s...
My Y31 has springs insted of bags and one of my struts needs replacing. thats why I took it out and compared it with an R31 strut.
the inserts are exactly the same travel distance and they fit into the base of the strut with the same screw type.
But I still dont know if the top thread of the insert will fit on the Y31 tophat.
If any one can confirm that. I would really appreciate it as i dont want the super hard ride of the JICs.
  • 7 months later...
  • 1 year later...
I seem to be in the same situation at the moment.
Front Coilies are fairly rooted on my Y31 Cima
Dont really want to put in some second hand ones...
Anyone know of any other options apart from the Jics?
Have heard of people converting the front of R31's overs to a S13 suspension setup
Just wondering if there is any truth to this as from what I can see it might be doable on the Cima
Edited by SideWaysChef
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
