  • Replies 90
Posted Images
only want that one coz Paul Walker drives it ;)
The fact you know the guys name who was in the movie indicates 2 things -
1) You watched the movie more than once cos you thought it was "great"
2) You are a regular over at NS.com.....*loads NS.com*.....well well you're over there too.....suprise suprise :D
https://www.sau.com.au/forums/topic/101708-hey-all/page/3/#findComment-1870518
i've watched 2 Fast, 2 Furious tons of times
i hardly go on NS.com ;)
https://www.sau.com.au/forums/topic/101708-hey-all/page/3/#findComment-1870662
lol this is hilarious, pokie has some serious fire in the belly. Once again welcome, if you are after a car coz some actor 'drove it', more like sat in it and had the action edited in then yes go for it. Otherwise take one for a drive then let us know what you think. Id rather meet the crazy guy who really 'drove it' like that lol. Im sure if you want to come on a cruise plenty will jump at the opportunity.....
https://www.sau.com.au/forums/topic/101708-hey-all/page/3/#findComment-1873356
So what's new? Meet some interesting people one here?
depends what you mean by interesting.
some people are alright i guess others are just..........
um i do know Paul Walker didn't actually drive it
it's the work of a stunt driver, but still i don't care.
i'll consider goin on a cruise, depends how i feel at the time
https://www.sau.com.au/forums/topic/101708-hey-all/page/3/#findComment-1880996
Turbz_13 Posted 18 Jan 2006, 09:57 PM
gday, im james and i got a skyline. unfortunately it is off the road at them moment tho.anyways , welcome to skylines aust.
welcome to the forum hope you enjoy it
Edited by pokie
https://www.sau.com.au/forums/topic/101708-hey-all/page/3/#findComment-1881028
Ummm.... not to say that i enjoyed the movie or anything, but he did drive in particular parts of the movie (like the slide sideways at the beginning...i think that is about it lol). Its in the making of the movie :D
Hope To catchya soon and enjoy chatting to the fella's :D
https://www.sau.com.au/forums/topic/101708-hey-all/page/3/#findComment-1882405
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
