im keen but i think ill have to be in for the next lot, no cash til the 10th of feb. sux gettin paid fortnightly..... :)
when is the next group buy starting?
is it possible to pm me back as i dont check the threads very often, only my pm's
thanks adam
btw is there a diff between pfc for a s1 and s2 r33 gtst?? will need to know b4 order so i can find our for definate
Edited by drag-on silvia
  • Replies 76
drag-on silvia - Not sure when the next group buy will be.
Both series 1 and series 2 use the same PFC.
bygrave316 - PM replied.
mrhele - PM sent.
We now have 10 buyers but the group buy is still open to extras, if interested ;)
:) Hey Paul, I tried to send a PM, didn,t work, so here is a post. I have put the cash into your account today as rquested so can you confirm I made it in time for my R33 GTR ASpexi unit and Commander? Sure would have to wait for the next Group buy! Regards, Rodd.
mrhele - very shortly. Most orders have been confirmed and are being processed.
I'll also send the tracking details once they are sent.
rodd - no probs. PM sent.
