  • Replies 134
Posted Images
Spoke to Bosch Australia today.
'Apparently' they have ZERO stock, Bosch Germany where the Z32's are manufactured have had a problem of some kind halting production.
I can get a very limited number of AFM's BUT no where near the 31 that we need at the moment. I have been told to call back every 2 days as it shouldn't be too long at all.
I'll make a few more calls tomorrow and see if I can scab some from various places around aus to make up the numbers.
Obviously I won't send out deposit details yet..
Sorry ppls, if your keen you may have to wait a little longer. :S
Its been a slow day today, many many phone calls. :S
I was unable to find a wharehouse that had any z32 airflow meters.
I'm expecting a call from Bosch tomorrow, I will know where I stand with regards to a time frame then.
Please bear with me as the group buy will definitely be going through.
WHEN is in the hands of Bosch Germany.
Aparently they are a bit scarce at the moment... I bought one less than a month ago from Petroject in Vic.. they said a number came in to the country from Germany, and they were only allocated 2 units of 10 that they requested. I got the last one they had in stock :P
They are indeed scarce.. :(
Bosch Australia have 20 items coming in. They won't be able to supply us with the required number of airflow meters until May. :D
Sorry for the hassle peoples. Early January the airflow meters were available, a production issue occured resulting in no AFM's. :P
I will PM every one as we approach the time and see if your still interested in an AFM and create a new group buy.
For those in desperate need for a Z32 (VG30DETT) airflow meter APC appears to have them listed at $360 which is a pretty good price.
http://www.apc-racing.com/browse.asp?cat=14&car=11
is this group buy still going on?
z32 fits r32 gtst right?
They will fit the 32 gts-t with the tomei plug or a plug from a vl but it will not work without a piggy back ecu or aftermarket of some sort.
Greg
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
