Just thought I'd share:
R33GTST
Mods:
10 psi
3" dump (batmbl)
3" CAT (batmbl)
3.5" Cat back kakimoto
Pipercross Panel High flow filter in stock box
R34 intercooler
PowerFC
Results:
BASE MAP: At 10psi gave around 145rwkw - see graph - AFR very rich and some aggressive timing in the wrong spots.
TUNED MAP: Around 172rwkw. I think final run was 170.9rwkw as some timing was taken out. On the dyno knock was kept below 20.
ON THE ROAD: Feels more repsonsive, but most gain is when you get over 3500rpm - 4000rpm. Going round corners the tacho flies towards redline as the expensive michelins battle for grip where they didn't before. Only thing is knock went to 58 on the way home. I might call the tuner in the morning..he seems to know his stuff though. I'll have to see when the knock is occuring. Hard to see on the hand controller..might have to get someone else todrive and have a look at the bar chart..
I should ad that the dyno is apparently quite conservative. Cars often make 5-10 kw at the wheels more on other dynos for some reason.
The tuners thought this was a good power level at this boost level with a fairly stock setup. I didn't ask for max power just a reliable tune. With light/medium loads tuned aswell.
Edited by benl1981
https://www.sau.com.au/forums/topic/102258-pfc-tune-result-r33gtst/
Nice power - yeah we both might have to talk to our tuners.
................. Before....................After............. Gain
3000rpm 100rwkw ............100rwkw
4000rpm 114rwkw ............116rwkw ..... 2kw
4500rpm 125rwkw ............134rwkw ..... 9kw
5000rpm 138rwkw ............153rwkw ...... 15kw
5500rpm 144rwkw ............164rwkw ..... 20kw
6000rpm 148rwkw ............170rwkw ..... 22kw
6500rpm 148rwkw ............172rwkw ..... 24kw
Not sure if the before and after are correct for the low rpm as he did some tuning at lower rpm before he did the power runs.
Edited by benl1981
Skyl9,
Compare average power of the safc to pfc. Peak power is not the be all and end all. THen there's the factor of dyno's provide different read outs, some lower some higher. :P
+ Its only 10psi, push 11-12psi and it will be definitely noticable. :)
Edited by Cubes
I have pretty much the same mods as you.
Do you have electronic boost controller? I use the PFC one.
I made 207 rwkw (hub dyno) at 0.7 bar (10 psi).
Was the hand controller used to tune? Mine was tuned using the Official Apexi Laptop software.
The FC Datalogit was used to tune it. No electronic boost controller. Just a simple bleed setup.
The tuner is the one Sydneykid recommends - he tunes 400kw hondas and many skylines. Compared to others he thought this is a good figure.
Not sure how a hub dyno reads compared to others.
On other dynos this could be 180-190rwkw. When you think it is only 10psi I am pretty happy. What do LS1s or Xr6T stock put out at the wheeels?
FFS Why do people keep comparing results of one car on one dyno with results of antoehr car on another dyno!?
You should all know by now that a dyno is a tuning tool - you can calibrate it to read onehundredmillionbaziawatts if you want to...
it's RELATIVE INCREASE that is important not the absolute number
benl1981 - good result and increase from tuning.
Thanks Ronin. Yeah I think people get carried away with "an R33 can make 200rwkw with these mods etc".
I didn't say to the tuner "others have made 200 etc" I was happy with the gain that he achieved. On the road the acceleration is much better.
I know Im not going to win dyno comps and I dont really care too much about the end power figure. This tells me the car is relatively healthy and running to its potential giving the mods I have.
Thanks R31nismoid. Yeah I'm not in ahurry to pull the turbo off it. The way I see it the next power increment is a little bit more expensive.
To go further than this safely:
Possibly new AFM $300
FMIC $600
new Turbo $2000
fuel pump $200
+other things
+time
+it won't look stock
About $3000 or more.
I know the car has a lot more potential but I'm pretty happy with it.
Probably similar in acceleration to a 250kw LS1 or XR6 turbs but I'm not really sure - maybe they would eat me I dont know. My smaller 6 makes the power up higher.
Skylines are a bit lighter - my car about 1400kg vs about 1700kg.
Quite an adrenalin rush now.
Sure I could push it and get another 15rwkw but how long does the turbo last?
Edited by benl1981
Yeah EBC should be your next step... then you can bump it up to 1 bar next time an XR6 with a front mount pulls up next to you B)
Plus the advantage of boost much earlier in the rev range.
Edited by Drift_Limo
I have a bleed valve on it at the moment, one of the $30 ones on the forums.
I might swap it for an orifice piece that goes in place of the standard solenoid. Then it looks more stock.. just thought Id get the tune on the bleed valve since it may bring boost on a little earlier..atleast then the load points are tuned
These cars seem to hold boost pretty well.,
Yeh ive been reading up those $30 boost controllers are pretty good. Supposedly there not even bleed valves. Id stick with what you have if your happy. Im going to go down your line of mods but i'll be doing a fmic when boost is upped.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
