Hi all..
Just rebuild my engine and have been running it for a week and today it died!!
It seems that the crank angle sensor completely seized up and snapped the end of the exhuast cam off!!
Has anybody ever had this happen??
Also, the 4 bolts that hold the exhuast cam gear on were scrapping against the crank angle sensor and there are metle shavings everywhere!!
Anybody shed some light on this????
https://www.sau.com.au/forums/topic/102397-this-has-never-happened-before/
I actually installed it and did it to the book...
Why is it touching the bolts???
I left the timing belt cover off, I think the sensor bolts onto this after the cover is put on so in theory, if I don't put the cover on, then, the sensor would bolt up that much closer to the cam gear, therefore, touching the bolts??
Does that sound possible???
This is very unlikely.....almost certainly the camshaft was cracked, possibly at installation. Under load with the engine running the crack progressed until the camshaft failed completely. The metal shavings, etc are probably from when the cam pulley bolts contacted the back of the CAS or the CAS mount at failure - the engine would have continued to turn for a short time after the ex cam failed.
I've seen a few failures of cams in RB engines as a result of incorrect installation - when doing up the cam cap bolts it's quite easy to put a bending load on the camshaft, and cast iron doesn't take kindly to that.
Anyway, that's my theory, I could tell for certain by examining the camshaft.
One other thing - you need to hope that valves didn't contact pistons.
Thanks for all your comments mate, I will take them on board....
The actualy cam is in one piece, it's just the very tip of it that the crank angle sensor slips onto that snapped off.. that piece is still in the shaft of the sensor when I took it off....
Does that clarify things anymore...
Take some pictures if you can, I'm intrigued by how much of the cam has broken off.
Yeah, I will try and take some pics of it.... keep an eye on this thread.. I'll post them here tomorrow..
I will be sure to put spacers in when I put it back together.. an expensive lesson!!
If I were to put aftermarket cams in, what would you all recommend and can I run cams with more lift and longer duration with the standard ecu??
I'm guessing that I can but I just won't get the power gains until I get the ecu changed....
Thanks all..
damn, I did so well with the rebuild too... Did it all and I stuff up something like this... feel like a damn idoit!! Ahh well, you live and learn I guess.....
If anybody has an exhuast cam for the rb25det, let me know..
I have been told that the rb20det is exactly the sam cam so I can use that if I have to......
The half-moon is only an aid to getting the angular relationship between the cam and CAS correct. The CAS keeps turning because of intermeshing of the teeth set on the CAS and the cam.
Without the half-moon, you need to visualise where they would line up. If you get it wrong, the engine won't run (but no damage is caused).
I would love to be able ti use the cam still but it didn't just snap off the half moon part of it, it snapped the whole spline off of the cam down to the end!!!
The whole piece was jammed into the CAS!! Nothing left for the CAS to grab onto caus it got snapped off down to the base!!
I just brought another cam and fitted it last night... Runs like a dream and yes, I've now put some washers in place of the timing belt cover so the CAS doesn't touch the cam geard bolts....
A valuable lesson learnt but if this is the only mistake I've made with the rebuild, then I'm as happy as a pig in....... ;-)
  • 3 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
