  • Replies 97
Posted Images
hello there
I am interested in the rear battery cover (as on the pic below)
See image
Would you happen to also have the "screws"/"nuts" (as per the pic below)??
I live in Melb.Kindly quote me a price including shipping ;)
Edited by anexiole
chasing the center console lid if the spring clip bit is still in working condition???
cheers
$20.
Will you take $50 for the dash?
Okay.
Adrian
hello there
See image
Boot trim is sold complete. Thanks.
Adrian
can you get back to me on the indicator piece and the left shock, thanks mate.
also a price on the air-con condensor and radiator.
Edited by SECUR1TY
hey mate do you have the tailshaft yoke? I will come down from sydney and pick it up tomorow...
yep - come get it.
SECUR1TY - Indicator stalk $60 as posted earlier - shocks all sold now. Air-Con condensor and radiator.....$200
Adrian
sorry i was looking for it last night i have already picked one up sorry mate i needed it asap. I'm sure it won't be hard to sell though il let people know.
GL with the sale of the rest of your gear.
is there any way you'd meet half way for this?
Whole car being stripped for parts - quick sale
Wollongong, NSW
All panels except bootlid damaged - mechanically great
Bought car for parts - lots left
Pickup only preferred
RB25DET, 5-speed, all driveline, some interior, 4 x standard S14 rims, dash components, headlights, tailights etc
ONLY contactable via email: [email protected]
Adrian
Do you have an undamaged front bar and what condition are your headlights/how much do you want for them?also the S K Y L I N E badge thing between the tailights,intact? how much?
Edited by BOVed
SECUR1TY - Half way to where mate? :)
Front bar has minor damage - headlights are in good nick - they work and with a bit of turtle wax on the lenses, should come up fine. Boot garnish is available too.
Front bar $90
Headlights $300
Boot garnish $50
how much for the float inside the fuel tank
sorry mate - wrecked the car with the tank in it. :)
im from bankstown so anywhere between where you are and here
I'm sure we can work something out. You mean the radiator/condenser for the air-con yeah? Not the radiator??
Adrian
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
