Friend sent this to me... I don't know how legit this is, but it sure is good to know something like this....
WARNING from NRMA and Police
You walk across the car park, unlock your car and get inside.
Then you lock all your doors, start the engine and shift into
REVERSE, and you look into the rear-view mirror to back out of
your parking space and you notice a piece of paper stuck to the middle of the rear window.
So, you shift the gear stick back into PARK, unlock your doors and jump out off your car to
remove that paper (or whatever it is) that is obstructing your view. When you reach the back of your
car, that is when the car-jackers appear out of nowhere, jump into your car and take off!!
Your engine was running, you would have left your purse in the car and they practically
mow you down as they speed off in your car.
BE AWARE OF THIS NEW SCHEME THAT IS NOW BEING USED IN SYDNEY AND COULD SPREAD ACROSS AUSTRALIA
Just drive away and remove the paper that is stuck to your window later, and be thankful that you read this email.
Hope you will forward this to friends and family. A purse contains all identification, and you certainly do NOT want someone getting
your home address. Especially when they already HAVE your HOUSE KEYS!!!
From
Loretta Peters
Dept of Police & Public Safety
Traffic Liaison Services
https://www.sau.com.au/forums/topic/102478-new-hi-jacking-technique-in-sydney/
in my car, once started, doors are closed and seatbelt is on my alarm activates the anti-hijack. As soon as i open any doors and take my seatbelt off the car starts to cut out after 2 mins. The only bad thing about it is that when i get home i cant get out and let the turbo timer do the job for me.
1st of all..
I got this email a few years ago, before I even had a car.
lol @ using real life things as spam mail.
good point whoever said u would probably see it before u got in.. but anything is possible.. if someone wants ur car they're gonna try their hardest to get it.
that girl on your bonnet will do a fine job obstructing me. alien were did you find her? more to the point does she have a sister
I'm up for going halves. :lol:
Screw that, I'll take two! And if she has a sister, it'll be two of each, thanks! :O
ahahah shes not even real ... he pasted her on there as you would notice if she was to stand up she would be VERY tall like 2.5metres or something lol.
Sorry for getting all your high hopes back down.
hey fellas,
Ive recently been granted my lic back and replaced my motor which i destroyed in my r33.
Is a nice example with a lot of work both cosmetticaly and engine wise. what im worried about is im on my way soon to visit my sister in cronulla.
what is the car jacking theft like there? I am not 100% sure ill drive if its bad. AS insurance wont come close to paying me out what its worth
thanks
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
