Hey Fellow Wagoneers,
I thought i might design & make a set of skyline tail lights to fit the stagea. I'll use the standard skyline lenses, but make up a custom panel so they fit in where the tail light go now. Below is a very bad representation of what i'd like to do & if anyone is good at photoshop you could give me a better idea.
so what do you all think?
If they come out really well, i'll start making some more for sale if anyones interested.
Regards,
Jeff
https://www.sau.com.au/forums/topic/102552-skyline-tail-lights-on-stagea/
I'm guessing if it was properly executed, then the look of Skyline lights on a Stagea could be nice.
I guess we'll have to see if anyone's good enough (and keen enough) to do a PhotoChop and we can go from there...
Having looked into this quiet a bit (as just did custom lights on my "project car" ... making a v2 as we speak) ... you'd have to use either 33 or 32 lights.
I've measured up 34 lights and the outta area of the stagea lights are too small to fit anything bigger than the 33. Even then they'll need to be placed so they sit slightly out of the normal light area (not flush to standard stagea rear lights). You could use 34 lights, but they're not going to sit well (as in flush with sides of car) on the car and stick out a bit
The inners are a piece of cake to do.
My only other concern using 33/32 lights is reverse/indicators, but nothing a bit of bog, fibreglass & some extended wiring couldn't fix l guess.
Somethign like this l was going to do (inc french boxing the no. plate down lower) .... but l cbf'd and would rather spend the time and energy on my other car. But if u do do it def. post up pics.
Edited by [ STAGEN ]
if you want a skyline wagon that bad... start with a skyline instead of a volvo :D
j/k
maybe the Option/Trial built R33 GTR wagon might give some inspiration. It resurfaced at this year's autosalon repainted white (used to be bayside blueish when it was made about 4 or 5 years ago).
Personaly I think the idea is great ...not using the round tail lights was something that the Nissan boys got wrong when they desighned the Stagea in my opinion. While most focus is on the the front, the rear has been sadly neglected...I still remember the first r33 I ever saw in the flesh my first view was the rear and its one of the cars best points..but then I have always been an ass man!....if you can make em I want em!
Scott.
Funny, i adore the ass of the stagea more then the front
but the longer and longer i own it, i prefer it exactly the way it is, as stock as it is. some wheels and maybe MAYBE a front bar...
Testify Brother! Can I get an AMEN! :P
Skyline lights on a stagea looks gay with aids. And I'm not just saying that to make fun of you guys... seriously, it looks so out of place. For starters the rear seems a lot wider than an R34, which means it looks misproportioned.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
