inark has a small penis
lol its a script enabled domain...
and gaddamn its never been put to better use :rolleyes:
sorry narkeh, I started denham on this, and as u can tell he's very highly amused.
BTW from now on every asian chick I meet I am gonna be very weary of.
denham has a small mind and as u can see small things amuse him... and i would probably be right in saying excite him.
theres heaps of these types of sites... theyve been around for god knows how long... i still cant remember all the ones with newspaper articles... i think i have them archived somewhere
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
