spewing here!...........
which engine should i buy?...it's there, but which is better?
hey all, just wanted to ask, since i've blown my engine pretty much, how much is it roughly for a decent R34 NEO RB25DET compared to the ones from the R33 GTS-T? (minus the turbo's as that seems to be the latest scam these days :( )
just also thinking, if i were to get the Neo engine, would it be a straight fit? or will i need a new loom and ECU as well (already have a MINES tuned to previous engine)? coz thinking that it is still an RB25 and all, wouldnt all the stuff be pretty much the same? how bout fuel systems?...anything else ive left out, please fill me in.......
OH YEA....and is 3months warranty on the engine enough? because if i get the R33 RB25DET then the guy offered me 6months
need to get as much info as i can before i have to put down a non-refundable deposit on tuesday for one of the two engines. :D
https://www.sau.com.au/forums/topic/102718-new-engine/
Personally it would depend on the price difference, how long you are going to keep the car, etc. If you want to hold onto the car for 5 years, then maybe the NEO would be better as its a newer engine, with probably more life in it.
But if you get a neo you will need the correct neo loom, ecu etc.. they won't be interchangeable with the older engines.
If it was only $1500 difference AND you thought you were going to keep the car for a bit longer.. then personally I'd go the NEO.. but if u just want to get it fixed, maybe drive it for another year, i'd get the cheaper older rb25
You would also have to look at whether the newer engine would need a separate engineering certificate to run it in your car. Should be fine from emissions (as newer engine), but you would want to check it carefully.. just in case at sale time you end up in a predicament.
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1886365
well......lets jsut say the rebuild would cost min. $3k, with a new engine costing about the same anyways.
just that this offer is pretty good right now for a NEO engine, just not too sure about how to get things done.
arkon, what kind of minor mods?
as far as the rep has told me, its just a NEO engine. meaning no turbo, no sump (need to use my exisiting one) as well as no loom either think...but will get back to you guys n gals on that one.
predator, if its pretty much same engine, why would i need engineers report?....might as well aniways for my otther mods aye..haha
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1886936
Seems you may be slightly confused...........
Rebuild engine: New internals, stronger, known quality.
2nd hand engine: standard internals, unknown history, unknown time in storage, more hassle (NEO conversion), unknown condition.
In my mind there is only one logical solution, but i'll leave that for you to decide.
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1887283
can see where you're coming from there Al, but at this stage of time, the "new" engine is about all i can afford. the upsides seem to far outweigh the downsides, but seems that the transplant would just seem to be the much quicker and more effective method at this stage of time.
Plus, mechanic seays the engine is now pretty much trash coz the cylinders are ALL cracked and the head is warped.....guess i blew it right aye? lol...well..guess only one way to go now
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1887906
Id rebuilt your engine depending on what you have f*ked ? but if you think it will only cost 3 grand your kidding yourself ... Parts maybe depending what you want to do or achieve. Dont forget labour and machining if you want to do it right you'll want to get the block cleaned, bored and honed ect. Aswell as some good internals.
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1887933
so arcording to that link sent by arkon (and i thank you for that), i should be able to use my loom and aftermarket ecu to run the NEO?....in a few months will need to buy a pfc anyway because can't tune a MINES ecu :(...but ..hope it all comes together well.
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1887953
cool...so the minor mods u stated with the wiring...would a mechanic be able to know what to do? like is it fairly straight forward common sense stuff? or would he have to read encyclopedias?? lol he's kinda old, but knows his stuff well. don't want to strain his brain too much.
how much would i be looking at for tuning this thing (if i got the PFC)? becoz i know the mines is untunable (shame*).
.......does anyone know a plastic welder in sydney?...i need to repair my front bar :)
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1891022
You'd be able to do the mods yourself. Have a look at my thread on it.
Reverse CAS wiring and find a plug to suit the VVT.
If you look at the wiring diagrams in the R33 and R34 manuals, you'll find it's pretty straightforward..
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1891096
.......does anyone know a plastic welder in sydney?...i need to repair my front bar :P
i know that franks panel and paint in seven hills does plastic welding..
also a bike shop in Penrith does it (next door to windscreens obrien)
dunno where you are but hope that helps
oh and modding the RB25 NEO is alot harder than the R33 engines.. interms of manifolds etc.. but internals are better
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1892308
cool thank Craved. was hoping to find someone closer to liverpool..or like bankstown region would be alright as well. sigh*
wonder how my engine is coming along. guys with the engine are installing my sump into it today, and taking the existing gearbox off.
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1894844
hhm..ok i picked up the engine today..........
.....stupid mechanic! says he doesnt know how to wire it up to run the [email protected] i gave a call to my friend's handy dandy guy....hope he can put it all in...
for all the people who've had the NEO engine put into their skylines (in general), where did you have it done and approx how much?...
also, if i dont get the loom (apparently you don't get this with an engine itself or so says the yard that sold me the engine), would i be able to wire it up to my existing R33loom, or do i have to get a new one?...or..wat do i have to do to get it up and running......
i can see now why some people say its a hassle -long sigh-
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1898445
thanks for replies people. mechanic will be checking out the motor tomorrow afternoon, and i'll get in contact with some motorbike shops to see if they can point me in a direction. ....
ok...mini-poll here okies? what is that wisest thing to do with..say $200 for my car?
1- tint
2- muffler (barrel and tip)
3- ...seat covers + floor mats
4-.................i really have no more ideas hahaha
so yeah. pick one that i've listed or just throw at me some ideas!
cya!
https://www.sau.com.au/forums/topic/102718-new-engine/#findComment-1900512
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
