How long is he down for and when? Also who's dyno is he using? how much is he charging? Is he just remapping ecu's or is he open to doing powerfc's and SAFC IIs?
Is there a thread about this?? !!!  :lol:
Its pretty obvious that if no one down here is good enough you'd take it to melbourne.
al_r33 racepace is own of the best known workshops for imports in australia. It's in melbourne: http://racepacemotorsport.com/main.html
still trying to organise all that.
can keep you posted if you like :D
If you wana copy a PFC map from another car to yours I've got FC Datalogit.
I got it in the car just never used it :lol:
If sam does come down i am pretty sure he is capable of tuning a PFC, he doesn't do remaps for R33's i dont' think (don't quote).
Sam is one of the best with PFC and he already mentioned ot me that he can bring his software down to do it if need be, just needs to be warned so he can pack the laptop.
And TIMMAY is correct, he doesn't do R33 ECU remaps
Ok for anyone that is interested.
http://www.nissansilvia.com/forums/index.p...st=0&p=1929952&
Numbers are limited but its worth getting in on the action as Sam will tune your car better than anyone in Tassie would ever dream of doing and if he dont and you think it could of dont better then i'll pay for your tune myself :D
Cheers B
Andy is doing a tune on my car on the 6th.  Iwill let you all know how it goes
Had my gtst tuned yesterday, very happy with Andy's work  :mellow:
SO how'd it go woolls.
You get the results your looking for???
Yes got 212 rwkw with an average 11 psi (safe tune). Car running sweet. be up for some splitfire coils soon though. Got some boost control problems ,but will fix that up when I get a chance. all in all very happy. :mellow:
cheers
Leigh
Edited by woolls
Yes got 212 rwkw with an average 11 psi (safe tune). Car running sweet. be up for some  splitfire coils soon though. Got some boost control problems ,but will fix that up when I get a chance. all in all very happy.  :D
cheers
Leigh
Got to be happy with that figure at 11psi.
How did the graph look, no lag midrange at all i take it???
Splitfire's would be nice, expensive but nice :D
EBC or mechanical
Splitfire's would be nice, expensive but nice :(
EBC or mechanical
lags not too bad, running a ebc (blitz)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
