I am interested to know roughly what 1/4 mile i would get out of my r33 with the following mods.
Garret T04E
40mm External Gate (with screamer) @ 18psi
ARC Intercooler
3" mandrel bend exhaust
walbro 500hp fuel pump
H/D clutch
K&N filter
nismo 550cc injectors
Z32 AFM
Power FC
I am having the injectors, FC & AFM installed next week, i pulled 214.4RWKW without those 3 items however ran stupidly lean, be interesting to see what i pull next week.
Just out of curiosity (knowing that there are variables involved) what other people have timed with approximately 250rwkw.
Edited by WNA-FLY
take it to the drags
what he said.... there are to many variables and none of us except maybe sydney kid :( are human dynos .... you will never no unless you take it down the strip yourself.
Edited by fEkuaR
Fair enough, was just wondering what people have been getting with around 250rwkw at the strip. will post results end of next week.
hard even with a power figure.
Who knows
1) how laggy/responsive the turbo is
2) the tyres/state of the track and stuff.
3) one of the better ones - the driver :(
Lots of other variables, best to hit the track and work from there as to how close or better you might be able to get
Who knows
fair enough guys. just curiosity and boredom got me writin up this thread.
will take all advice and put it on the track.
Dave.
Will have to be after its tuned next week.
sorry for this thread, seems like I'll have to just find out for myself,
lol just wanted to see if all my money is gettin me anywhere..
Edited by WNA-FLY
we like to joke...
sorry for posting this thread, seems to have caused much wasted time for all parties.
i was being serious :D
I wanna know what your results are gonna be dude B)
Hardly wasted anyones time, was a easy question to answer, hardly done harm :O
i was being serious :(
Hardly wasted anyones time, was a easy question to answer, hardly done harm  :)
LOL haha, too easy to mis interpret peoples comments on a computer (sorry for that) ;)
ProTek will be on the job next week and will then take it down to Calder on one of its friday night's. will keep posted.
Would like to see if my money is well spent. Knowing my luck I'll take it to the strip and fry a piston. hehe :lol:
Edited by WNA-FLY
216rwkw and I am only getting 13.4 at wsid bad wheel spin in first (not even dumping it the locker helped a bit) and 171 kph so nice top speed
265's 18's on the rear and olims suspesion so not really set up for drag stip.
so if its going to be a drag car, you might think about some suspension mods.
Edited by race_snooze
Without taking everthing into consideration ie. 1) how laggy/responsive the turbo is
Can't anyone with the same (estimated) power figures as WNA-FLY give him a rough estimate of what kind of 1/4 mile time he should be expecting... (ROUGHLY).
P.S I will be going to go down to calder next friday night might see you there.. :(
P.S I will be going to go down to calder next friday night might see you there.. :D
Yeah tyres are gonna be my biggest issue with loss of time (plus the fact it'll be my first time on the strip) can anyone reccomend a grippy set of tyres.?
Im running 17X9" Volks on the rears if that makes it easier for a suggestion.
thanks
thanks
Buy a cheap set of 16s and get MT drag radials!!! then you could expect somthing under the 12.5 mark with some practice!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
