um guys i was just wondering what kind of difference does it the cold air box make to the induction (sucking) sound??
at the moment with just my k&n pod it really sucks loudly, just wondering wat kind of difference the box will make to this sound as i am in the process of putting a box together...
i've got one of the UAS partitions, and havent noticed any reduction in noise after the install! depends on how sealed you make the box and intake ducting, wont get rid of the noise i dont think!
nice neat kits, been working well for you the last 2 years Jay95r33??
LOL yeah, It's been about 2 years !!
I found that the one that I made did reduce the noise a bit, but I think it had more to do with the insulation stuff that I used on the inside of the box. The insulation stuff is about 10mm think of foam, with one side being heat reflective foil.
J
where did you get that insulation matting from? got any photo's of the matting Jay?
Yepp, sure do :( Here are a few more pics of it getting made up.
The insulation stuff I got from Clark Rubber, not sure what it's called, but it was about $40 for a square meter.
J
G'day Croat - we made the box fit around the intercooler pipe work. To install the box you have to disconnect one of the pipes and feed it through etc...
Doing this keeps the box very stable and doesn't let it move around at all (it a tight fit !). So there's no need to screw the box down to the bodywork at all.
J
sweet, been looking for something to seal mine up with..  :(
shame you had to cut into the chasis in the guard there, im just using a CAI from the front bar up into the old hole from the IC!
thats what i've done but i've been thinking recently if we ever do get any rain here in sydney, water from the road will come straight up onto the pod = bad,
any ideas how to reduce this guys?
Jimbo i have had my pod with a large induction pipe going from my front bar to my pod via the standard intercooler hole... I was a bit sceptical about it at first but have checked many times and have never had water in the area as a result of it... i dont think the water will be able to travel upwards so easily. Just try keep out of those large puddles, but with the weather as is i would not worry...
well seeing as the air does not need to be forced through the pipes to the box, perhaps as modified type of u bend (yes like a sink) could be used to trap the water!! atm, i can see where water has entered that area from the holes in the chasis from the original air box!!
any other suggestions?
  • 2 months later...
Hey guys, jus regarding 'noises' the cold air induction systems make, Say i replace my stock ryco panel filter with a K&N panel filter (inse the stock box) will it make any significant make in induction noise? (im a sucker for that sound)
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
