Finally, here are just a few tempters that give you guys an idea of the calibre of cars on show in and around Japan.
Beer Baron and I returned from Japan this morning after 2 weeks of soaking up the mecca of performance cars
Lets get things started:
We visted the Nismo Omori factory where we were treated to a private photo session involving both the sought after Z-Tune R34 GTR, and the R1 Spec R33 GTR - If these pictures dont excite you, you dont deserve a Skyline!
Need a new RB26? Omori can assist you for a modest fee!
Tokyo Autosalon proved to be a smaller show that previous years, but there was still a plentiful display of eye candy (and some nice cars too!)
Im not sure, but apparently there were promo girls in attendance?
Trust / Greddy had some great high mount kits on display
22's - The must have accessory for your BMW
One of our UK comrades from the GTR UK forums owned this incredible full Carbon fibre body R34 GTR that was just finished by Sunline Racing in time for Tokyo Autosalon. In fact the owner told me that Autosalon was the first time he had seen the car, since handing over a stockish white coloured BNR34 to the guys at Sunline with the instructions to make it a monster.
The car is running a built NUR spec RB26 with Trust T517Z turbines
One off custom made SSR wheels, with the mother of all spacers residing behind them
Beautiful looking S14 sporting the new Vertex bodykit
More to come :D
  • Replies 40
Blitz,
you guys suck big time. Id love to go over to japan for a couple of weeks......Those pics are sweeeeet! Its good to see greddy investing wisely in its promotion department. How much did the trip cost? and how was it getting arround over there? or can you guys speak japanoey?
here he have a nice JGTC supra just for the supra weirdos out here.
took it out, it's too big and will fark the thread. will repost in a bit when i learn how to use a computer...
here is one for the freaks that like 4 door 32s. well all 4 doors for that matter. this was built by Autech Tsukada and from memory has an RB26 in it? nick can confirm i'm sure.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
