hey all my name is sam and i finally got around of taking a pic of it. Its a s1 r33 gtst. Mods include
-cat back exhaust
-air filter-bov
currently in the process of buying a split dump and front pipe + a high flow cat however getting cash is a bit hard as im still young
https://www.sau.com.au/forums/topic/103283-hey-all-pic-of-my-car/
well i turn 17 on the 31st of january so basicaly from then onwards i can get my p's il try get them asap =)
cool :) i remember when i 1st got my skyline, i was too on my L's the way to get my P's was soo long (felt like ages). hehehe i hated taken the bus to school everyday :)
Looks tidy, good luck with it. My 33 was my 2nd car, got it on the road for 17k, have spent about 2k so far, and probably on the weekend I will be able to pick it up again, to the tune of around 7k. :)
I'm an apprentice but have made & can save enough money to own a car like this, people will ask why spend so much but I have my reasons & my satisfaction. :)
  • 1 month later...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
