Bought a VS Ecotec the other day. Thought it would be cheaper on fuel, oil changes etc. than the Rb20
She developed a big end knock so I stripped it down and they're worn out at 180K's. Don't people change oil anymore?
But the worst thing is it's such an absolutely crap engine. I've never worked on something so poorly designed that you just can't tell if it's going to work or piss oil and water out everywhere.
Then on my adjacent engine stand is my old Rb30 block which has done at least 400K's. It's still got the hone marks in the bores and the crank is perfect. That's nitriding for you instead of the cheap crap rolled crank journals in the Holden.
The Rb is destined for a big power build up. The Holden is destined for another place.
https://www.sau.com.au/forums/topic/103624-ecocrap/
Sure did. Had a VP as a company car, did 275K's without a hitch. I bought it when I moved and just drove to Perth, all the West, South you name it. Just added fuel and did one oil change. Not a power giant but 8L per 100K's. My mistake was I thought the ecotec was the same engine but with a newer ecu etc. It's a completely different engine.
https://www.sau.com.au/forums/topic/103624-ecocrap/#findComment-1905196
LoL....it's a Holden. Did this come as a suprise to you?
It can happen to any car and guess what, it can even happen to a NISSAN :) what a shock. :P:)
My RB30 was sludged up with crap a while ago, am I going to blame this on its Manufacturar, Nissan? No because its just one of those things that happens.
https://www.sau.com.au/forums/topic/103624-ecocrap/#findComment-1905219
my VS has 279 000kms, still good 'cept for a minor PS leak. been reco'd tho. by "other day" how long ago? did you buy private or thru a dealer. i got mine thru a dealer for $5500, it got a full on service, and when it developed a PS leak (the first time, and as all commodores do) i got a new PS Pump installed aswell as new sway bar links and bushes.
What date is it? any ecotec before june/july '05 are f*ked. seal leaks, oil leaks etc etc...
https://www.sau.com.au/forums/topic/103624-ecocrap/#findComment-1905223
my mistake was I thought the ecotec was the same engine but with a newer ecu etc. It's a completely different engine.
I looked up what the upgrade to "ECOTEC" status entailed:
"The comprehensively upgraded ECOTEC V6 benefited from low friction technology and included a new cylinder block design, lightweight, high-compression pistons, lighter cylinder heads, new Bosch throttle body and sequential fuel injection."
So yeah there is quite a bit of difference there. New ECU, new block, new heads, new pistons, new throttle body, new fuel system... Not a lot of the old engine left really! I assume the basic design is based of the same 90 degree Buik V6 from 1954 the original VN V6 was based upon, but it seems most components have been comprehensively redesigned. I was going to say "improved," but I will leave it at "redesigned" :P
Edited by Big Rizza
https://www.sau.com.au/forums/topic/103624-ecocrap/#findComment-1905230
Ill tell ya another holden 'oil' story. my brother had a holden and there is a constant reminder of that aussie junk, thanks to the huge oil stain the car produced in our garage. That car left a lasting impression that will never leave us, and insured that no holden will ever enter our home again.
If we got visitors with a holden, you best believe their car is to never enter our property and stays parked on the street outside.
https://www.sau.com.au/forums/topic/103624-ecocrap/#findComment-1905367
My mates VS Commodore is jinxed... Its had just about everything fixed or replaced.
He had huge fuel problems with it getting about 300K from a full tank... spent probably $1500 trying to get that fixed and it went up a little bit, but not before the engine shagged itself at about 150,000K.
So got the VT Ecotec put in there and extractors, exhaust and suspension done all at the same time... Had had probably 4 problems with exhaust comming loose and bolts coming out of it, had power steering problems... The works...
Not a bag to all holdens but I know this one is deffinately jinxed!
https://www.sau.com.au/forums/topic/103624-ecocrap/#findComment-1905399
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
