  • Replies 130
i got an EL luminous dial kit yeasterday from e-tronic at parramatta for $150. great price took a lot of ringing around though and they can also make custom ones in any color witch also illuminates
Pred:
during the day the dials are white, at night with the lights on they can be either blue or green (switch) and also dimmed (on the switch)
I seriously could not go back to the stock dials (never had them in the first place but im sure you know what I mean)
is e-tronic the same as SRALLY
Unit 2, Grose Street
NORTH PARRRAMATTA
9683 5880
?? I might give em a call n ask em if they can do it for an R32 as well, coz they dun make EL kits for R32's. Otherwise its back to trying to used ultra bright white lights instead of the standard backlight... I so can't see my cluster even witht he dimmer turned all the way up.
yeah funkymonkey its the same place.
they will make you a custom one for around $300.
mine was $150 cause it was a el dials of the shelf item.
Jimbo sorry no pictures yet as i havent installed them yet. im going to have a go at installing the today.
if you want a set from e-tronic you better hurry and remember to take cash.
i installed mine yesturday, and im very happy with the result i think they look great. and i cant complain for $150.
i took the new dials and instrument cluster to a couple of instrument technitians around my area, one wanted over $200 to fit it and all the rest wouldn't even attempt it?????????? for fear of wrecking my speedo and all calibration.
so i figured i am a mechanic so why not try it my self.
i done exactly what inasnt surgested, take the needle stopers out and let the spring loaded needle come to a rest. then mark the resting spot for the needle. take the needle off. take the old dial off. replace it with the new el luminuos dial. put the needle back on in exactly the same position as i maked it, then turn the needle around till its past the stoper point then replace the needle stopper
i checked my calibration and its all still spot on.....................
was fiddly but a good result and more satifaction cause i done it my self...........
the instrument technitians can go **** themselfs.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
