Hi guys, I was hoping someone might know if the R34 GTR(NEO) Vspec, series ll, 2001 model carries the grey 14 pin Nissan DDL?? (consult port)
I have R34 NEO on my list of cars that my cables and software work with but it just seems too new???
Thankyou,
Caz.. :)
Edited by caz
Didn't the Consult port change in 1998(ish) from OBD1 to OBD2?
caz you'd know better than me but I think NewKleer mentioned something about it in one of his threads.
I didnt think the GTR was ever OBD2 compliant? This is why it was such a pain to import them into America (and Motorex had patented the compliance process to bring it up to OBD2 specs, which is why they were the only cars that could do them). Could be wrong, but pretty sure thats how it was.
