Ok, so i run std radiator and there is always talk about what temp the coolant should not exceed.
Looking around the net i cant find any info on what general temp an alloy head cannot exceed, ditto RB series engine.
I have just bought a new probe that will measure head temperature, i always pull the pin when the coolant temps nudge 90-100. The actual head temp whoudl give me a better indication when to back off...shouldnt it?
https://www.sau.com.au/forums/topic/103848-head-temperature/
Hi Roy, I am not sure that I completely understand the question. It is not the maximum temperature that causes cylinder head or head gasket issues, it is the temperature differential that causes warpage or, in extreme cases, cracking. For example exhaust ports can be upwards of 800 degrees C, water jackets max is around 110 degrees, inlet ports 60 degrees, combustion chamber temperature etc
So where you place the sensor determines what temperature you are likely to see.
:unsure: cheers :D
:P cheers :rolleyes:
This is why they invented water injection pre-turbo to lower all the combustion chamber temps... by over 35% :ban:
...no thanks...may work great, but watter isnt that compressible last time i checked, andi dont have that much faith in control systems, be it the car tuned for it and then you run out of water...or a problem means one day you start your car and BANG bent rods :P
*cough*mechanical water injeciton*cough* dont buy cheap china stuff that runs off electronic components.
Using your (probe?) placed somewhere on the cylinder head casting will give you a fair idea on whats happening.
I dont think water injection is used to cool down the cylinder head as much as cooling the intake charge.
I see cyl heads on an almost daily basis that have overheated and have gone soft. (i usualy ditch the head any where under 65 brinell)
Good idea to have an alarm at a certain temperature!
I only heat the heads around 80-90 celcius when pressure testing.
The only time i pressure test hot is if the customer has a water prob and we cant find it and/or the head has been welded etc.
Why dont you keep an eye on the temps and watch for any changes?
Make sure you tell us some details.
THe xr6t's have a cylinder head temp sensor right in the middle between the two valves on the back of the head no 6 cylinder. At 300rwkw a 10 second dyno ramp can yeild a rise temperature from around 90deg to 110-115 degrees. I would have though at this temp the coolant would start to boil?
Hi Roy , some years ago Craig Allen from Allen Engineering in Mallala said they were using multiple coolant temp probes along the head of an RB30ET . This was done because when souped up the head was suffering localised overheating I think down the back and some plumbing alterations were used to get more even water flow and temperature along the length of its head .
Most engines probably use water temp probes at the front or where the water outlet to the radiator is . Doing it this way should be ok but when power output is pumped up its difficult to know whats going on at the other end of the heads water jacket . Craig said something along the lines of 86deg at the front of the VLT head and 110 down the back .
I think major dramas occur when there's localised boiling and steam pockets form in the jacket , where there's no water there's no cooling so localised thermal overload can cook/warp/crack the casting . I have seen examples of heads that have small water lines tapped into high points in the jacket to give any bubbles an escape path usually to a header tank which is the highest point in the cooling system .
Any way I suppose another water temp probe down the back of your engines cylinder head would tell you if the coolant temp was even along its length .
An exhaust temp probe between the head and turbo would be handy because if the temp got out of hand something may fail before the water temp gauge could tell you particularly if your racing and need all attention on driving the thing .
The rally people tend to use a bright dash light and loud buzzer to warn them of
imminent doom ie for oil pressure/water temp or whatever they choose to hook up .
I think there is available head temperature probes for air cooled engines such as Dak Daks (VW's!) but I'm not sure if it would tell you anything useful on a water cooled engine . Either Allen Engineering or Nizpro have used a temp probe under spark plug type washer but not sure if its purpose was head or exhaust gas temperature .
Gary is there any specific issues with the RB twin cam heads and water cooling ?
Cheers A .
...110-115 degrees.  I would have though at this temp the coolant would start to boil?
The water doesn't boil for 2 reasons:
1. It's under pressure - pressure affects the boiling point of water. On top of Mt Everest you can't have HOT coffee because the boiling point of the water is so reduced by the low atmospheric pressure. Inversely, higher pressures RAISE the boiling point.
2. The "coolant" chemically modifies the water so it boils at a higher temperature. For the same reason, they spread salt on icy roads because the salt lowers the freezing point of water.
Basically this is why you NEVER remove the radiator cap from a hot engine - the water is likley to go "super-heated", and suddenly turn to steam.
I have pictures of an NA race RB20, and it has a big ass coolant lien at rhe back of the head, mush like you see at the front of the head/plenum???? mayeb they had worked out a cure for the temp differential? Or is that i have never paid enough attention in noticing this line on other RB engines before?
don't think this answers your question, but was talking to a race engineer and he said that they don't worry too much if there is a ~20 degree difference between water and oil... even up to 120degC on water... they run alloy heads too but I guess temp control across the head front to rear may be the key (ie. maintained temp across the head)?
All that system does is make sure that there is no air trapped in the engine. All the water lines feed upwards to for areas where localised trapped air is possible. Does NOTHING for improved water circulation.
;) cheers :)
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
