  • Replies 58
Hahaha - yeah thanks Jax.
A friends has season 2 on DVD as well - but I didn't want to watch it all in one go - then have nothing to watch each week.
Draws the suspense out more this way. :ban:
Season 2 hasnt finished being aired in the US yet. how'd he get all episodes before they did!?
https://www.sau.com.au/forums/topic/103987-tv-lost/#findComment-1911981
:( - Shame on you!!!
JK - but cmon give me a break - at least I wasn't excited about McLeod's Daughters, Big Brother or some other crap!!!
Hehe true.
Thank god your not excited about Big Brother! lol
If i watched lost from the start i probably would be into it to. So if you wanna get me into it i need to watch all of season 1 :rofl: Oh boy lol
https://www.sau.com.au/forums/topic/103987-tv-lost/#findComment-1912120
I missed season 1 and I'm not a big TV watcher but I am hooked on season 2 of lost.
I have just finished watched SE02E12, so effectively Australia is 3 months behind. I'm right into it!
The first 6 or 8 eps finished with me hanging for the following week.
A couple of the eps are a bit bland further into the season, but it's pretty good. I'm addicted!
https://www.sau.com.au/forums/topic/103987-tv-lost/#findComment-1912941
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
