I replied to the R33 idling problem thread but to no avail. So i'll make a new topic.
After driving around for like half an hour and then park it, when starting up again the car will idle really low (from like 800 (normal) down to when it sometimes stalls). But after say 5 minutes it's all good again. Any ideas people?
Thanks
Scott
https://www.sau.com.au/forums/topic/10399-idling-problem-with-r32-gts-t/
Someone asked the same question in another thread, someone else suggested that it was the earth wire coming from the fuel pump. He said it needed to be earthed to a new area near the rear of the car. This way the fuel pump will operate at 100%. all the time. check the thread out, its in the 'performance' part.
When some dicks replaced the timing belt on my car (under warranty) he had it 1 tooth out on the exhaust cam.
This made it chew the fuel and idle weirdly. It would move up and down from 800 - 1200 rpm.
Once you turned the Air-con, it nearly stalled.
I don't think this is your problem, but you could always check it out.
Check the AAC valve, and clean it. Its the little valve located at the back of the plenum chamber (inlet manifold). Its what controls the air bleed at idle. Works like a screw moving a needle valve. If the screw or needle gets sticky, it lurches rather than run smoothly.
Where can i find the fuel filter? Is it the big metallic cannister thing below the intake plenum thats fairly visible and has a big clip to hold it to the chasis? Is it the one with the tube that goes in the bottom, and the tube that comes out the top and towards the fuel rail, or is it further back near the fuel tank, e.g. under the car? I should check mine i guess, although my problem is not on idle, but more under foot to the floor condition.
Just that on previous cars they've been much smaller.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
