  • Replies 1.5k
Posted Images
Yep I think you may be right bout Mark-but Flav owns him and if Flav gets the shits old Marky Mark will go to Renault. Renault has the better car for Mark but Sir Frank has the better team culture for Mark
Edited by gtr660hp
Thats true-sometimes old Flav is out of the loop-oh well he still got his 200 foot boat filled with expensive piss and naked euro models-tha bastard!!!
Id like to see webber go well this weekend
I'ma bit sus on what these cars are gunna sound like with the V8-bring back the V12!!!! Fark nothin like them especially the Scuderia V12 -Santa Maria!!!!
Mind you the cossies are punchin near the 20000 rpm mark so who knows
Edited by gtr660hp
the SOB used to bang Hiedi Klum!!!
But on a Motorsport note.... i think next year the V8 sound will be insane cause thay would of had over a year to develop the engines. considering these spec engines are relativly new they are just begining to understand them. Give these guys a year of R&D and they'll hav the engines reving well over that!!
when does webber's contract run-out with williams? he's always been "owned" by flav and renault in terms of contractual dealings etc... williams had to "buy" webber off flav. i believe he is still under contract to him..... mark will do better this year, cause the williams is a much better car this year than last year. im not sure i'd say that the renault is the car which would be better suited to him, just look at barrichello, changed teams and cant drive the honda for crap! but the renault is certainly the fastest......
did anyone watch practice this arvo? i did. i have to say, Wurz and Davison were bloody impressive. if the williams can get the tyre situation sorted out, which it looks like they might be on top of, they might do surprisingly well. Patrick Head didn't give much away when they interviewed him afterwards, but he was quietly confident.
Jenson looked the goods too, but i think the renaults are holding back a little.....
Well its raining at the moment..i personally feel Webber has more then average talent in the wet...will be interestign to see if the Bridgestons have any wet weather pace though...ditto Williams.
A wet race could be the variable Williams need to bridge that performance gap
looks like bridgestone havnt got shit this year, its a maclaren renult race i reckon... i wouldnt worry too much about Button
saying that those mclarens are amazing in real life!! they way the reflect light of the paint is just sexual
P.S the V8 supercar race was pretty fcukin good today aswell...
The last few mins of qualifying was good. Kept changing and changing. I was joyed when Webber slotted into P3 with a few mins to go then all of a sudded the Renualts and Mclaren and Button must've taken some super drug cause they just shot up the slots and Webber was back down to P7.
qualifying was awesome! drama and action packed, i thought. but what about the race??? damn shame about webber, i was so disappointed. he was on for a podium, 3rd for sure. lucky theres a 3 week break now until Imola, some teams are gonna have a long and expensive repair bill. have to feel sorry for Massa and Button. for once Massa didnt take himself out of the race and jenson's last corner blow-up was so unlucky. but how good was it to have Murray Walker back commentating? i loved it. he's still the best.....
i think the last corner was the place to sit this year. schmi puts it into the wall and then montoya puts in a 180km/h drift down the front straight and managed to catch it!!
if Kimi stays at Mclaren next year with Alonso they are gonna be an unbeatable team... did you see how they both swolled up Button with no dramas?? fcukin excellent
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
