I'm sure you guys have had a chance to check out the JPNZ manuals (legitimate copies of course) of the Skylines. A couple of years ago I got the japanese service manual equivalents and was astounded by the amount of detail that was left out in the english translations. I guess it cost money to translate a lot of trivial stuff.
In any case, rather than stick around for someone to translate the stagea service manual, I bit the bullet and bought a copy of the Japanese service manuals on CD . I bought it so I could better work out a Stagea/Laurel/Cedric AWD RB25DET transplant into my R32 GTS4.
I bought my copy for $140, and its not that easy to come by due to some shrewd japanese auctioneers playing bidders off against each other. I'm happy to offer a copy of this to you guys for $20 (postage included to anywhere in Australia). I'll only be selling enough copies to make my costs back, after that you guys are more than welcome to do with them amongst yourselves as you please. Seeing as I just bought the manual about an hour ago, it'll be a week before I get the master copy, and a week after that before you guys recieve it. In this time I'll take expressions of interest in getting a copy (simply reply in this thread). Once the necessary number of copies have been accounted for, then I'll send em out.
Here's what's covered:
Models
  • 20G
  • 20X
  • 25G
  • 25X
  • 25RS
  • 25G-Four
  • 25X-Four
  • 25RS-Four
  • 25TX-Four
  • 25TRS-Four/RS-Four
  • 25TRS-Four V/RS-Four V
  • RS-Four S
  • RS-V
  • 20RS
Included Manuals (ID shown in brackets)
  • New Model Introduction - Sept 1996 (F046813)
  • New Model Introduction - Aug 1997 (supplementary Ⅰ) (F046844)
  • New Model Introduction - Aug 1998 (supplementary Ⅱ) (F046870)
  • Main Service Manual - Sept 1996 (A046001)
  • Main Service Manual - Aug 1997 (supplementary Ⅰ) (A046002)
  • Main Service Manual - Aug 1998 (supplementary Ⅱ) (A046003)
  • RB engine RB20E, RB25DE, RB25DET Engine Manuals Sept 1996 (A260W10)
  • R4W71C, RS5W71C and FS5W71C, FS5R30A Manual Transmission Manuals - March 1987 (A261B06)
  • RE4R01A Automatic Transmission Manual - March 1987 (A261C07)
  • F160 Differential Manual - March 1990 (A261D05)
  • R200, R200V Differential Manuals - March 1991 (A261D08)
  • ETX13A 4WD Transfer Case Manual - Sept 1992 (A261K02)
  • Steering Gear and Power-Steering Pump + Rack and Pinion system Manuals - April 1993 (A261H04)
  • AV System and Navigation TYPE I Manuals - June 1997 (A264A05)
  • Service Technical Information (STI)
  • Connector Summary - Feb 1993 (N200005)
Also includes the following diagnostic manuals:
  • CONSULT - Engine - May 1989 (J00E000)
  • CONSULT - Traction Control - Aug 1991 (J00W000)
  • CONSULT - AV system - Aug 1991 (J00V000)
  • CONSULT Common (revised edition Ⅰ) - March 1991 (J00M001)
  • CONSULT Service Manual - RB engine - March 1991 (J10E004)
  • CONSULT Service Manual - Automatic Transmission - March 1991 (J10T001)
Couple of screen grabs:
Now, ALL THIS INFO IS IN JAPANESE, so it may not be useful to those of you who don't have the patience to translate it or work it out. However it is still handy to have, if you have a basic understanding of how to read a service manual.
Again I repeat, this is a JAPANESE manual, not a translated english one. However it is more intricate and thorough than any english translated service manual I've read for a japanese import.
The manuals have been stored in Adobe Acrobat 7 format, so you'll need a compatible reader to open it. All chapters are bookmarked for easy navigation, and each book is stored as a seperate PDF.
https://www.sau.com.au/forums/topic/104317-japanese-stagea-service-manuals/
  • Replies 306
Posted Images
It covers series 1 and 2 from what I understand.
I assume these supplementary volumes are for updated engines etc:
Hmmmm, time for Japanese lessons? I know Japanese is not an easy language to learn, but like Terminal says, pictures can help make up for deficiencies in understanding what's been written for the time being.
When you get enough numbers, I would be more than happy to meet up with you when you're next in Sydney, if that helps. I'm only about 15mins from the Dundas area.
Cheers,
Nick T.
hey mate awesome find, and just wondering if it has wiring diagrams for the attessa system? and  general wiring for interior stuff etc?
if so ill grab one for sure :( let me know and ill send the cash once u r ready  :D
cheers
Brad
ATTESA wiring and diagnostics included, as are full wiring diagrams for the car. It also has a section on how to pull the interior apart if that's what you're after.
From looking at the fast software, it looks like the return line connects back into the surge chamber, i can't quite tell but it looks like the fuel pump mounts inside this, i'm guessing it's a plastic enclosure of some type.
It's showing the return line connecting into the bottom of the surge chamber (tank).
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
