  • Replies 306
Posted Images
hmm yeah melb to melb should have arrived a long time ago. Might check with the guy that does the postal run (sent with company mail) to see what was done and if he has some sort of tracking.
ive been searching the net everywhere for the manuals and maybee a mate at nissan can scource them for me.if so guys id be only too hapy to share them with u.lets hope hey
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
