I deleted the neo plug in first post, as I could not find it on the nkg website, I've asked before but does anyone know what they are using in the Neo?, the $650 is for NEW stock coils in factory box.
It is confusing yes and with so many things that affect the firing properly I have learnt from this that the best way to track a problem is to check,
1. your coils for cracks and with a multimeter.
2. the plugs for useability and the right gap/heat for the boost you are running.
3. the fuel is the right Ron rating
4. the tuner did a good job of getting it right.
You can cover 123 easily enough but 4 is harder, it is more to do with the timing that is dialed in for the problem phase but would be a rare one I think. And to think all I wanted to know is what plug to use lol.
  • Like 1
$650 brand new coilpacks I would have thought to be a damn spanking good price.
Either way, with a group buy I dont think its worth it. I went down to my local autobarn (which really arent too bad...) So yeah, went down there. Said I want 12 of these. They said come back in 2 days we'll have them. Low and behold they did. $3.50 each or something. So if group buy fails, you know your going to do 'x' changes a year, just stock up.
Have a look over at NGK's web site and check out their part number break down.
The BKR7E plug without a dash something are pregapped at 0.8mm. 0.8mm will be fine.
Throw a -11 on the end and they are 1.1mm.
Also the S on the end will indicate they are a std non v-power plug.
EDIT: They are around $4-$4.50 each.
i removed V powers from mine n replaced them with bcpr7es which worked great for 2 days them felt yrs old, im gonna gap them to .8 this weekend n see.. got rb25 run bout 10-12psi usualy exhaust the usual did i make right decision n should i gap em down? what do you recomend? thanks
Not sure.. I found the standards at 0.8mm would feel a tad flat in the top end vs the v-powers at 0.8mm.
I'm not sure if it was this thread but I remember some one mentioned they had to gap the standards slightly smaller than the v-powers to prevent break down.
If you have BCPR7ES then they are already at 0.8mm. If you have BCPR7ES-11 then they are 1.1mm.
For 10-12psi you most definitely want 0.8mm.
:P
Opinions on ideal gap size?
as large as your ignition system will support. a small spark doesn't set fire to the mixture as efficiently as a big spark. Therefore you should stick with 1.1mm where possible.
however, if your spark gets blown out by running higher boost then you will have to either gap it down or improve your ignition system. guess which method's cheaper!! :D
1.1mm is no good... He will need 0.8mm. Every body who runs boost needs 0.8mm :P
1.1mm is no good... He will need 0.8mm. Every body who runs boost needs 0.8mm :D
either that or buy new coils :D
Edit - should note that I just gapped my plugs in the 31 down to 0.8 - not worth a full set of coils when gapping is that much cheaper!! :P
Edited by Kinks
You'll find even new coils won't make any difference to a good set of coils that are not arcing out.
When I say boost I do mean more than standard. RB20's get away with running a little bigger gap for the boost run.
Depends if the origional coils were nackered or not.
If so then yes the spitfires are better. :P
basically.. If your cars running fine, 12psi or over and running 0.8mm gap, throwing a set of spitfires in isn't going to allow you to run a bigger gap. The spitfire coils are nothing more than stock coils painted blue, they don't offer better performance or anything just a new coil that isn't arcing out on its bracket. :D
when i oredered them in i asked for BCPR7ES and on the box they came in there was no -11 at the end so if there already at .8 what should i do? just upgrade to the V-powers? the bit i dont get is why they worked absolutly awesome for 2 days then went ghey... for those 2 days it felt like new car !!
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
