I deleted the neo plug in first post, as I could not find it on the nkg website, I've asked before but does anyone know what they are using in the Neo?, the $650 is for NEW stock coils in factory box.
It is confusing yes and with so many things that affect the firing properly I have learnt from this that the best way to track a problem is to check,
1. your coils for cracks and with a multimeter.
2. the plugs for useability and the right gap/heat for the boost you are running.
3. the fuel is the right Ron rating
4. the tuner did a good job of getting it right.
You can cover 123 easily enough but 4 is harder, it is more to do with the timing that is dialed in for the problem phase but would be a rare one I think. And to think all I wanted to know is what plug to use lol.
  • Like 1
$650 brand new coilpacks I would have thought to be a damn spanking good price.
Either way, with a group buy I dont think its worth it. I went down to my local autobarn (which really arent too bad...) So yeah, went down there. Said I want 12 of these. They said come back in 2 days we'll have them. Low and behold they did. $3.50 each or something. So if group buy fails, you know your going to do 'x' changes a year, just stock up.
Have a look over at NGK's web site and check out their part number break down.
The BKR7E plug without a dash something are pregapped at 0.8mm. 0.8mm will be fine.
Throw a -11 on the end and they are 1.1mm.
Also the S on the end will indicate they are a std non v-power plug.
EDIT: They are around $4-$4.50 each.
i removed V powers from mine n replaced them with bcpr7es which worked great for 2 days them felt yrs old, im gonna gap them to .8 this weekend n see.. got rb25 run bout 10-12psi usualy exhaust the usual did i make right decision n should i gap em down? what do you recomend? thanks
Not sure.. I found the standards at 0.8mm would feel a tad flat in the top end vs the v-powers at 0.8mm.
I'm not sure if it was this thread but I remember some one mentioned they had to gap the standards slightly smaller than the v-powers to prevent break down.
If you have BCPR7ES then they are already at 0.8mm. If you have BCPR7ES-11 then they are 1.1mm.
For 10-12psi you most definitely want 0.8mm.
:P
Opinions on ideal gap size?
as large as your ignition system will support. a small spark doesn't set fire to the mixture as efficiently as a big spark. Therefore you should stick with 1.1mm where possible.
however, if your spark gets blown out by running higher boost then you will have to either gap it down or improve your ignition system. guess which method's cheaper!! :D
1.1mm is no good... He will need 0.8mm. Every body who runs boost needs 0.8mm :P
1.1mm is no good... He will need 0.8mm. Every body who runs boost needs 0.8mm :D
either that or buy new coils :D
Edit - should note that I just gapped my plugs in the 31 down to 0.8 - not worth a full set of coils when gapping is that much cheaper!! :P
Edited by Kinks
You'll find even new coils won't make any difference to a good set of coils that are not arcing out.
When I say boost I do mean more than standard. RB20's get away with running a little bigger gap for the boost run.
Depends if the origional coils were nackered or not.
If so then yes the spitfires are better. :P
basically.. If your cars running fine, 12psi or over and running 0.8mm gap, throwing a set of spitfires in isn't going to allow you to run a bigger gap. The spitfire coils are nothing more than stock coils painted blue, they don't offer better performance or anything just a new coil that isn't arcing out on its bracket. :D
when i oredered them in i asked for BCPR7ES and on the box they came in there was no -11 at the end so if there already at .8 what should i do? just upgrade to the V-powers? the bit i dont get is why they worked absolutly awesome for 2 days then went ghey... for those 2 days it felt like new car !!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
