I want my car to run mid to high 12s. Heres my plan:
Trust V-SPL coola 600x270x76
K&N pod with cai
Full stainless 3" exhaust including dump
s-afc
boost at 12-13psi
255 street tyres
everything else stock
Will that be enough? I may also add a heavy duty clutch if I need it. At the moment the only mods I've got are a cat back zorst and k&n pod and best so far is a 14.307@98mph on 205 tyres at normal inflation.
What hope do I have?
https://www.sau.com.au/forums/topic/10443-i-want-12s/
With those mods you want you should get about a 13.2?
Youll need a bigger turbo, T3/4 or TO4 should do the trick with a larger fuel pump and fuel pressure reg. Dont run huge boost due to high compression in 33's.
Z32 AFM
550cc injectors
reduce the pressure in your rear tyres.
Knock your timing to around 18 degrees.
Run very good fuel 100+RON
Make sure tuning is spot on.
That should get into the 12's if you know how to launch well.
https://www.sau.com.au/forums/topic/10443-i-want-12s/#findComment-166559
Mate,
Check out my 13.4 'how to' thread. Do what I did. It will cost less and if you add the 255 tyres (I'd go simex to get more traction for your $$$) you might crack the 12's without the S-afc.
If you can get the 60ft down to 1.9 a 12.9second pass is on the cards if the car is a carbon copy of mine. Think about it 12sec pass without any extra fuel management.
here is my thread about the 12sec. pass.
http://www.skylinesaustralia.com/forums/sh...=&threadid=9445
https://www.sau.com.au/forums/topic/10443-i-want-12s/#findComment-166624
Originally posted by rev210
Mate,
I checked out that thread... the reason for starting this one :) . Over your setup I'll have a full zorst, pod with cai, safc, 3psi more boost, and bigger tyres... minus the flywheel and pineapples. That should be worth more than half a second right???
https://www.sau.com.au/forums/topic/10443-i-want-12s/#findComment-166674
Originally posted by riggaP
I checked out that thread... the reason for starting this one :D . Over your setup I'll have a full zorst, pod with cai, safc, 3psi more boost, and bigger tyres... minus the flywheel and pineapples. That should be worth more than half a second right???
I have a full exhaust, the turbo to cat is thermo wrapped.
The Pod isn't any better than the K&N panel filter I have.
There are plenty of guys with a S-afc, more boost and big tyres and such who don't even crack a high 13, let alone a mid 13. What you are proposing dozens of people have already done and have not achieved even 13's let alone 12's.
The pineapples are a 'must have'.
The flywheel alone is worth 4 tenths.
The larger intercooler might hinder your 1/4 mile time if you are using the stock turbo, unless its rated to 300HP or just under. Besides I don't think you need to spend the money there to get the 12's your after.
Have fun trying, I know I always do.:)
https://www.sau.com.au/forums/topic/10443-i-want-12s/#findComment-166729
OK so basically with the setup above plus pineapples, light flywheel, high flowed turbo, slicks, all professionally tuned, and with me learning to launch it properly, 12s are possible.
A few quick questions,
rev210: why the pineapples? You say pods arnt any better than panel filters. So why is it that almost any hi po car in magazines use pods not panels?
meggala: did you shave almost a second off by just having good tyres/suspension setup? Do you recommend hard or soft suspension?
https://www.sau.com.au/forums/topic/10443-i-want-12s/#findComment-167909
Originally posted by whatsisname
Hey Rev, out of interest what yr model is your GTS25t?
Matt - he has a 1995 model. I swear the 1995 ECU's have different maps. When I run mine up on a dyno I'll try the 1995 and the 1993 ECU's I have and compare.
I found a web site in Japan that quoted all the different firmware updates for the nissan ECU's, and just in the R33 GTS-t's there is about 7 different versions !!!! But they didn't say what the differences were :D
Rev210 - a bit off topic, but did you wrap your front/dump pipe in thermal wrap while it was still on the car, or was the pipe off when you did it??? I'm thinking about doing mine and I just hope I don't have to take the damn thing off to do it :)
J
https://www.sau.com.au/forums/topic/10443-i-want-12s/#findComment-167962
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
