I have just finished a spending spree on my car today, ending with some discounted products from Supercheap (10-20% off stuff :) ). Heres my list for the month of Jan 15th-Feb15th (I get paid monthly on the 15th).
I am still waiting on the top 4 things from Nengun, ordered 3 weeks ago today :D
-Remote Oil Filter Kit
-Apexi TT + Harness
-Wheel Spacers
-HICAS Lock Bar
-DBA 4000 Rotors
-Ferodo Front Pads, Lucas Rear Pads
-Mobil 1 Engine Oil
-Oil Filter (from Nissan)
-Oil Flush, Radiator Flush, Brake Cleaner, Ultra Cool Radiator Coolant
-Demineralised Water (5L, is that enough for the GTR cooling system?)
TOTAL=$1,344
This month I hope to buy a PFC D-Jetro (+ Harness, Nipples & Sensors) and get the HICAS and TT fitted and the computer tuned.
Good Fry B)
Tom
https://www.sau.com.au/forums/topic/104474-monthly-expenses/
  • Replies 40
Posted Images
,4 Feb 2006, 04:17 PM]1.3k thats nothing :P i'm not going to dare add up what i spent this month on my car, it will make me cry :D
hahah, dooo iiiitt! B) **shakes fist
Well, The PFC and tune is gunna cost me about $1600 anyway, so that beats my 1.3k this time around, I might even have to get a PRofec B-Specc II as well coz I have no boost controller at the mo ;) . This is the most I have ever spent on my car in a short period of time though.
ive spent minus amounts on my car this month :P
ive got alot of parts sitting in the shed, new and used, so im trying to sell stuff now that i want to sell the car :D
hell, ive even got brand new custom number plates that i havent even put on the car yet, still sitting at the DPI... should sell those.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
