I Dont ***in Believe It
  • Replies 129
yo inasnt, if you need a car to smash into the cops house, you can use my VN ifn ya want
feel for ya man, ya cant do shi.t though cause ppl voted in that Bracks jerkoff and we cant do shi.t till the next election
maybe you need to stalk bracksy......
hey now theres an idea
bwuhahahahaha:)
Guest INASNT
update
just came back from the epa test.
about 15 mins and i was on my way.
They looked in the engine bay, under the car, in the interior check that the afm was working and the stock boost controller was connnected, did their polution test and noise test. I recorded 83 db.
Guys there are preety nice and said i wont be asked to come back again unless the cops provide some sort of evidence that my exhaust has been changed.
When i was pulling out a MY01 Sti WRX was pulling in, they have been targeting skylines and wrx's recently!
Now time to put all my stuff back on.
My car is so quiet with the stock exhaust and air box, sometimes at the lights i have to check if the car was actually on. :P
hey u ain't got 185rwkw now...liar!!! for now...D
Denham I saw u the other day sat morning u were at chandler & heatherton rd. intersection, was gonna wave but u would've thought, who's the freak in the 120y chugin along....:P she puts the power down real well got traction thru all gears, she's tip top!! :D
haha I'm surprised its still in one peice with all the bog....man she's a real work horse, it carried two trannies 1 in boot and 1 in rear seat mate she still body rolled with all that weight and it was like dumped off its tits.... :P
Guest INASNT
i had to drive around a 120y as a courtasy car once when my old car was being repaired. I had to use a pair of plyers to hold the choke open for about 10 mins in the morning or otherwise it would run properly! doing 100km/h in that thing felt like about 250km/h in a normal car :P
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
