are these the D1 style drifters? at work and cant open the vids. If so, i bought Ken Nomuras ER34 Blitz D1 drift car from Japan recently. The Battery doesnt last long, but they are good fun otherwise. SO many aftermarket parts you can buy for these things.
New wheels, coilovers, bigger batteries, bigger motors, sticky tyres etc etc..
i cant seem to find anyone in australia that sells though rc drifters, looks like a lot of fun!
These have been around for a while. You actually modify a remote control car to drift by changing the tyres. Those look like battery operated cars you should try with petrol power heaps more power.
Yeah just get a RC car of ebay or somthing, i think most drifters are electric not the petrol ones, i find the elexctrics work heeps, better, you can jsut put PVC pipe on the back wheels and it works perfectly, my mate and me bought a Awd petrol one, put a 2speed in it, and put pvc pipe over the back wheels, the pipe most hardware storse will give for free as its only a tiny bit, needed.
Edited by Michael_1882
normally they are 4wd cars with drift rings around the tyres or cheapest option is cut up pvc pipes and glue it on the wheels.
if you want cheap way go for the Tamiya TT01 or TB02 with PVC pipes.
if you want the good stuff go for the Yokomo Drift package, these will give better control and hold difts for a long time. (more info go to yokomousa.com)
If you guys are interested, I import these on special order.
Hey SXR
Yeah i would like a set if you can. How much with postage to Melbourne, 3038?
Hi All,
A company in the USA called Yokomo specifically builds 1/10-scale electric RC drift cars. They work by placing hard plastic / rubber rings on the rear tyres which, combined with the torque of the 540 electric motor allows you to drift them.
They all come with clear Lexan plastic bodies which represent cars that are or have plied their trade on the D1 circuit in Japan.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJDB8&P=ML
This link should answer a few more questions. Tower Hobbies does ship to Australia and they are far cheaper than most of the Aussie hobby shops (sorry to say that, but buying in bulk has its advantages, so does a lack of GST :( )
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
