i have 9 rb30's most of them I have got for free or under $100 dollars!!! You just have to wait for them to come to you, its like when you don't have a missus all the ladies are not interested but when you do have a girlfriend a girl that you have loved for 10 years comes up and says she likes you(damn), if you appear deperate the rb30's will be hard to find let them land in your lap is my experience!!!hahaha
Just do it, there arent to many circumstances where I would recommend against a rb30 and for you inteded purposes you will love the 3rd gear power burns!!!!!
  • Replies 52
Posted Images
When too much torque is never enough.......
You can always de-tune a motor. It's a far better way to go than having to tune harder to get the same power. Rb30 would be quite easy, just pull some timing in the right spots hey presto you have the curve you can live with.
I so far have not seen any posts in years about how easy it is to tune power 'out' of a motor on purpose. So many people tune the hell out of their engine first and then struggle to get the thing to stay on the road under throttle. Your right foot is also a wonderfull power and torque controller, I call it the first line of traction control.
That makes sense...but seriously, isnt it like buying a 30 tonne crane to lift the engine out of the car? Sure it will do it with ease, but the initial expense only not to use what you have built/bought to capacity????
So if you wind igntion out of the engine so that its a bit flatter and more driveable...whats the difference between usng the available ignition and getting the power out of a 2.5L???
As for right foot, unfortunately mine isnt engaged to my brain, so whilst torque may win races, my experience of a few cars i have been in also means it fries tyres...so somewhere/somehow there must be a compromise.
I think we all need to remember that primarily we are driving road cars here...
...and im not trying to say RB30s arent ay good. Its just that from what very little experience i have with them is that its the torque that everyoenis chasing that makes them break traction...i dotn understand why the opposite is generally claimed. Take a 230rwkws RB20 that hooks up fine, and either a 180rwkws RB30 or 220rwkws RB30 and they seem more willign to break traction
If you find its too savage another method to prevent wheel spin is to take advantage of the torque and drop a higher diff ratio in it.
There's plenty to choose from from VL style ratio's right up through the 3.7's, 3.9's 4.08, 4.11, 4.363 and also 4.6
Here in Adelaide RB30's are everywhere for ~$100-$200.
I have 2 sitting in the shed.. One has a bad gudgen but in otherwise perfect condition.
Just as a comparison.. Tractive effort.. Torque..
Mine making ~190-200rwkw has the same tractive effort as an Rb25 making 313rwkw, being ~390-395nm.
An Rb30det making ~312rwkw makes ~540nm. Huge difference.
There appears to be one downside with the rb30det... If you plan on running the stock exh. manifold expect your rev range to be limited and power to begin dropping off over ~5500rpm.
It would hopefully also pick up fuel economy... Possibly.
Since the tune and new clean injectors I'm getting awesome fuel economy in the order of 10.6L/100km's.. Just the injectors and a new o2 sensor prior to the tune saw 11.1L/100km's.
I personally think the diff solution is a bit of a bummer...
Piston speed to road speed, raise the ratio high enough and it will have the same torque getting to the rear wheels as an rb25 or even rb20 maybe. :S
Fairly pointless, especially if you stuck with the stock exh. manifold that restricts rev's a little. :D
the rb30was a gift .... its just the simplist bang for buck and has all but superceeded the car it was released in as far as parts available and development gains ...
there is a massive aftermarket following much cheaper per HP gained Vs dollar than any of the other Rbs as far as bolt on parts now and i believe because of this!!!!
i have had all of them now and although the rb26 is tuff when fresh i dread working on it as apposed to the old 3 litre dime a dozen....
Roy,
You can tune torque in or out of the motor very easy, hell you can make a power curve to any shape that suits your traction issue fancy. The fact is the Rb25 may not ever get the kind of torque you would really like where you want it the way an RB30 can.
You tell a good tuner what power you want and when and they will most often do it for you, it's not that hard. Most people unfortunately just walk in and say 'power'. Think about this next time you get a dyno tune, the easy way is with a 2 stage boost setting or even better a dial that operates between two settings seamlessly.
I think Im going to look for an RB30 block this wkd, lol, have been offered the timing belt and other parts already! Guy thats offering is a mechanic at local Nissan dealer, hmmmm, food for thought!
I'm thinking of going the cheap way -
Get a RB30 block
Re-Ring and hone it with the standard pistons
New Big End Bearings
Drop my Head on
Drop the sub frame 15mm
Bolt the other bits back on..
Drop it back in the car
Grab a wideband o2 sensor...and go for a street tune (do it myself because we seem to have rip off tuners here in mackay)
If I had a bit of extra cash, I'd balance the crank and shot peen the rods.
How much boost can standard RB30 pistons take?
It's more to do with how well it's tuned and being careful, if you push them a bit far on the dyno or something, they will just shatter and that will be the end of it, while forgies or something will be more forgiving.
But yeah, plenty of people run them with success so go for it I reckon. :(
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
