  • Replies 78
WOW
That would be the fastest mph ever run on low mount turbos I think
you would be correct...old mark was 136.8 MPH
well done....low mount's kick ass!!
Edited by DiRTgarage
Paul (DirtGarage) has done a 10.3 @ 133mph on 2530's so that shows that their is probably still a few tenths in it for Justin (xrated) with that mph.
Yeah thats correct...but also have ran 10.41 @ 136.8
Hey Justin...i didn't think anyone was slower through the gears than me...lol
Ok before anyone gets too carried away. I ran 10.675@ 137.62 mph, I ran 50 hp shot of gas. I went up the return road and straight back onto the track and ran 11.087 and only a couple of mph slower (don't think the gas is lean enough yet). The friday night before I ran up 393rwkw on 24psi of boost ( the actuators couldn't hold any more boost) and that was after 10 or 12 straight power runs on the Dyno (should make over 400 cold).
So make of it what you will... I'll be running next round without gas (they'll let me run without a cage with no gas), so I'll see what happens.
Either way 10.6 with a 4 wheel spinning launch and crap 1.66 sixty foot, isn't bad for stiff coilovers, no susp set up, street legal tyres, full weight (bar passenger and back seat) GTR and a STOCK bottom end!
( A well chuffed ) Justin Hallock
What street tyres? Does Paul run a BFG or MickeyThompson tyre?
Damn that's awesome result, i'd love to have a steer of either Pauls car or your car Justin... well done guys :D Must be crazy to drive on the street or on a track..
Yeah it's nuts on the street..... I run BFG Street drag radials, like i said, a full wheel spinning event to launch, I really need a tourque split controller!
With the cams and a little fiddle with the timing, my t517z's sool up verry close to stock...
Edited by XRATED
We run M/T street drag radials
Unfortunately I don't own the car Tommo, Stace has taken back the keys (after i broke it)....or id give you a drive...lol
She has allowed me to run the car with the Croydon boys at a private track hire to try for 9's...meanwhile we will be trying to get her into the 10's
Ive got the same problem.....its the worn transfer case.
Croydon's are modding one for us with extra clutch plates in it...worth a thought
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
