thought i'd post up some pics of my first skyline a 1996 GTR V-Spec, i'm a noobie to this site and skylines this is my first and i'm lovin it. i've got huge plans so keep checking back for updates. any feedback is welcome
Mods: Haltech E11V2 ECU
3 1/2 " HKS Exhaust turbo back
HKS power air filters
18x9 1/2 Volk TE37's
Ganador mirrors more coming soon...........
Edited by MrVspec
https://www.sau.com.au/forums/topic/104895-welcome-to-my-gtr/
  • Replies 90
Rims really do set it off.
Hope their not to painful to keep clean with brake dust.
What a joke i thought the car was gonna be hard to keep clean but the wheels are a joke. but hey small price to pay meguiers wheel cleaner keeps it under control.
i also have white wheels, i know your pain.....
Edited by 85URK
How does that wheel cleaner go, i have white wheels too and the brake dust is a bit of a bitch. It doesnt mark the rim or anything?
wheel cleaner is the best makes the white sparkle like new with no marks
i think ive seen your car mate, nice work.
is it a private import?
Personally hand picked by myself with Zac from SVI's help
next mods on the cards will be a jim berry clutch then out to the track for some fun.
yeah a few people saw it there i saw yours there the other day i only work just down the road at Custom Carbon @ Geebung just doing a whole lotta carbon stuff to mine at the moment i'll post up some pics as i finish things
Very nice. Never thought the whites would work with Purple after seeing Leewahs but it's good.
Love the 18" TE37's for getting into the Bremmies to keep then clean. Originally thought of ditching mine because of the size of the rubber but worth keeping. Mine are bronze.
Get the GTR cruises started, I'll be back in Qld in a few more months.
Added mine btw but being 95 doesn't have the nice headlights.
Here I thought I had the rarer of the factory colours being purple :D
Bloody poping up everywhere!
Love the wheels on the purple car, had considered then thought about dark car [wash twice a week] + white wheels [wash every morning] = :P
Your a gtr virgin, i bet you still have a grin when you go to sleep at night :D
Edited by TOY 33
yeah i was just saying that to nick 83GTR was gonna organise a GTR cruise i'm sure we'll get a good turn up. yeah i got a grin when i go to sleep at night and the best thing i work at custom carbon here in brissy wait til u see what i'm doing to her all hail to carbon might i add got a sweet set of plates coming too
Mmmm custom carbon...I can see us becoming good friends already :blink:
Need some underbody stuff.......like a rear diffuser for the track 25t and the GTR
BTW GTR lovers, my mate Pete (Bass Junky) is doing some pretty nice ally air guides at a good price if you wanna get in on it http://www.skylinesaustralia.com/forums/in...opic=95289&st=0
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
