A few of us NSW hoodlums are coming down to cause trouble down there and are going to go cruising on the Great Ocean Road. Anyone interested? Also can someone suggest a few meet points as I'm not a local and don't know where you guys are.
Thanks.
*edit*
Meet: 10am
Where: Geelong Botantical Gardens
Map
Alternative meeting place: Maccas on Ring Road
Time: 9am
Where we going: Apollo Bay.
https://www.sau.com.au/forums/topic/10497-great-ocean-cruise-10th-march/
  • Replies 147
I am keen [as mentioned in GP thread].
We may end up needing a few different meet points - ppl in the city / east could meet closer to city [perhaps near docklands?], ppl in west could meet somewhere central to them [werribee plaza?] [or just geelong] and then the main point somewhere in Geelong is probably the go I reckon.
Cardinia Park / Shell Stadium in Geelong [football ground] has a pretty big car park area, and is on the main highway too! [would have to check if there is an event on for that day though].
My Bro works in Geelong. i could ask him about a meet point if need be.
FYI: from chadstone s/c to torquay takes me 1hr 15mins on a good run [speed limited to 100kmh of course].
Oh SWEET!!!
Gald i found this thread.
I'd be KEEN as. Count me in 100%
I'd love to take the R for a burn.
Is it a drive down there monday.... come back monday ?
If it's an overnighter... we can go as far as Apollo Bay and stay there.
I've got a holiday house.
Can only sleep 4-6, rest in tents.. plent of lawn space.
I'll have to work out if i can have it 100%.... depends on the level of interest.
My vote is a meet at shell staduim.
Near the end of geelong so it can be used as a catch-up point as well.
When the R31 forums come back up i'll post it over there as we are thinking of exatly the same thing that weekend :D
Sweet, finally I get to meet you guy's!
Just got my GTS-4 2 weeks ago, needs a few things done to it but will definitely go to this cruise:)
Can I suggest a meeting place?
Geelong waterfront botanical gardens, on the top carpark facing Corio Bay. It's a good place to take a few pics too:D
Any disagrements with Geelong waterfront botanical gardens? I ain't local so speak up if it ain't good. Meeting point is Geelong cause some of us NSW people don't know the ins and outs of the city. I know how to get to Geelong, but someone's gonna have to show me where this garden is. Also be on the look out for a silver R32 GTR with www.skylinesaustralia.com on the back. That's me and would appreciate if someone could help me get there.
Time, between 9 and 10am. Any good bbq spots along GOR?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
