  • Replies 46
You coming mate? I need a co-driver. Heading up Friday night.
Me? Yeh looking at heading up, happy to take shotgun if its on offer, i think shotgun has already been called in the Lada
Are you sure you know what you are doing...im pretty sure i will not be able to stop talkignabout that great game by the Tahs the other week..who were they playing again :):) :lol:
https://www.sau.com.au/forums/topic/105198-deca/page/3/#findComment-1965904
At the risk of the Vics throwing up in their latte's :)
Pity I missed it, but mate the seats there for you.
Waratahs 16 Reds 12
Fists flew and blood flowed as NSW exorcised another demon to mark the start of their Super 14 campaign by grafting a late win over a tenacious Queensland last night. It was NSW's first win in Brisbane since the Super 12 started 10 years ago.
The visitors' poor kicking game and the Reds' never-say-die attitude forced NSW to dig deep in front of a crowd of almost 40,000 that bayed for blood, which was delivered at regular intervals in a niggly and frequently violent game.
The brawling started in the first minute and peppered the match at regular intervals, but never escalated to a point where referee Matt Goddard was forced into action.
https://www.sau.com.au/forums/topic/105198-deca/page/3/#findComment-1966035
  • 4 months later...
does anyone have a copy of this? sorry to dig up as i still wanted this for my wall. i brought the issue before this one, so ended up getting the wrong one. if anyone has a copy of this article please let me know, willing to buy it
https://www.sau.com.au/forums/topic/105198-deca/page/3/#findComment-2316509
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
