  • Replies 419
Posted Images
finally received my switch
looks good and very professional
now to go use!! :)
thanks
has been tested on a private road
and let me just say, this product is awesome
works 120%
and no more having to get out of the car, or reseting the car!!
top work guys!!
works 120%
top work guys!!
Thanks for the feedback Matt, top stuff!
parcels sent to kozeyekan, race and rally repairs, whitesky, mr benno, allblitz and crimmo.
still to mail last two out to oosx and Dynamix....will try and get those off tomm. guys
as you may know we have been very busy in the last week with racing and the car.
We appreciate your patience.
Paul and Stacey
I've gone through all 8 pages, not once did it say it is ONLY for R32. I also stated that i want one for my R33 GTR - i should have been told this. So its useless on a 33?
Sorry for the misunderstanding...YES...this only works on R32 GTR's and R32 GTS-4's. Please PM me your banking details and ill refund the cost of the item plus return postage.
Apoligies again for the stuff-up
i want one, please pm me all the details :P
parcels sent to hot53x and MR MAD.
will make another batch of 10 if there is enough interest.
so far i have...
slimjim
arrow
intouch
GTS-070
Nutsack
DVS32R
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
