  • Replies 419
Posted Images
To be fair to the guys who have already paid, like...jazree, slimjim, Mr Cali, and hanyou. ill do this batch in two lots of five....so i only need 1 more name to make up 1/2 batch and send out....then ill start taking names for the final five.
p.s. the final five could be the last batch of these made up....im over it.
Edited by DiRTgarage
I'll pay the money into the account 2moro lunch time!
Been busy with uni, so sorry about the delay!
So that'd make me the last of the 5.
Ali.
Edited by IOWNU
Hey!
Any news....rough approximation if possible?
Thanks.
Ali.
6 parcels sent out today...yes you are one of them
parcels have been sent to the following people
IOWNU
jazree
Mr Cali
slimjim
J-Boy
hanyou
can this be used on the r33 gts4???
and can i switch from 4wd-rwd-4wd without turning off the car?
sorry only r32's compatable
and yes switching can be done without switching off ignition
Last batch...names in and paid are as follows...
justinfox
neshgtr
please pm if you are interested as there are only 4 of these left (i did say batches of five but i have six this time)
Hey,
I recieved mine earlier this week as well.
Very happy with the product!
Thanks for your efforts DiRTgarage.
Thanks guys (add to trader rating if you like)
ive just realised i forgot to add the cable ties to the bags...sorry :/
Trader rating added. I wondered where the ties were haha no biggie :/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
