wow! clickety click
sorry if it's a re-post.. the firewall at work wont let me view the ceffy & other 4 doors area... so i had to go to one of my old posts in here and click new topic.
(good reason for a re-post don't you think lol!)
anyway... what's your opinions?.
I have mixed feelings, i like the idea, very unique and probably look great in the flesh but i don't know... the pictures kind of make it look weird.
Cheers,
Dave.
*edit, hope this link works better*
Edited by DJ984
Nah I am not a fan! I love the look of the cefiro front / lights....why make it look like another R34 Skyline???!!!!
The whole point of having a cefiro is to be different.....you rarely see another Cefiro on the road!! :D
Best bit everyone is like WTF when they mistake the Cefiro for a slow arse family car and then.....VVVRRRROOOOOMMMMM PPSSSHHHTTT :P BYE BYE
I tend to agree,
The front end it totaly out of proportion to the rest of the car. Nice idea but it does not do it for me. Why ruin a perfectly nice looking ceffy?
Dont Like it either, front end looks to big for the body, i have seen it in flesh it is diferent but im not a fan. As you say the whole family car sleeper style rocks my socks :D
FBI = Different. But mmmmmmmm not keen
Looks shit. No attempt made to blend the front bar in. 34 4 doors and Ceffys look awesome in their own respect.. This is just bad Joojoo
Go stick ur shitty r34 nose onto an s15 or something.. 17k LOL... Wonder what he payed for it. What a Jackass
ha ha! yeah, not many positive opinions coming out here eh... I actually thought the nose was a bit small not big though... seems to sit to low / sloped / off shape.
Ando : I'd love a ceffy man... put an rb25 / 26 / 30 det in there, a work shop x kit and some 33 gtr rims and she'd be tough as nails. But not really in a position for any of that at the moment lol!
Car is slow at the moment... playing the waiting game :D PM me and i can fill you in with more details
Cheers.
  • 4 weeks later...
lol you guys are way too harsh... not that I'm a fan of the mod or anything, and I think the blend job looks wierd the R34 front dosen't suit the shape of the cef back.
that said... we did this, so I can't criticise:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
