currently been thinking about upgrading my HKS GT-RS turbo on my R33 GTST. im after the 320 rwkw make but dont want a laggy ass turbo. Currently making 260rwkw and bored of it.
What turbo's have you people seen make 320rwkw without too much lag (preferably HKS turbos). considering the HKS 3040 but not too sure on how it goes.
any help/dyno graphs will be appreciated.
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/
320rwkw shouldn't be difficult to achieve with the HKS3040R or Garrett equivalent provided you do have a built engine. I think there are a few people on here who can personally vouch for that...
I've got a GT3040R on my R33 making around 280rwkw on 17psi (see dyno graph below). I've only got a std bottom end, so I haven't really pushed the limits of the turbo too much at this stage, but there's definately potential to make a lot more power.
Obviously it's not going to be as responsive as your current set up, but full boost by just over 4000rpm isn't too bad when you making approx 300rwkw.
Hope that helps :rolleyes:
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1942129
The Garrett GT3040R is rated is 600hp.
SEE HERE
I also forgot to mention that i have the 0.82a/r turbine housing, so I guess you could go for the 0.63a/r if you wanted less lag, although power would come on like a light switch which would make traction a bit of a problem. The 0.82 is nice and progressive.
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1943555
Wouldn't the 0.63 choke the top end too much and stop you from getting to 320?
What about the GT2835 Pro S with the 0.87 rear housing? That should get you there.
What was B-Man running when he had 330rwkw? Was that the 2835 or the 3040?
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1944036
I used to think that 300+ would be pushing it with the 0.63, but after seeing Wilchs results in the rb25 dyno thread - i.e mid 270's @ 16-17psi with a .63 GT30R on rb25 w/std internals (I think?) - I guess 300 could be possible with a little more boost and a rebuilt engine.
I think it was a HKS3040R from what I remember when I was researching a while ago (may be wrong)
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1944288
1.0 Japanese PS = 0.98632 BHP
actually PS is not a japanese measurement. i dunno where you got that from but it's the (old) german standard of horsepower. it stands for Pferdestärke which i am quite positive is not japanese. basically means horse power in german.
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1945350
That had a lot of stuff done to it to get that.
An R33 RB25 head isn't the most amazing piece of gear and it's still only 2.5 litres.  Imagine how peaky 300-350rwkw would be.  Sounds ilke a waste of time if you ask me.
I'd agree. Much over 300rwkw and its gonna be peaky.
My setup (in my opinion) with the 600hp GT30 was as late as i would want a turbo to come on (4200/4500rpm/17psi)
With a redline of high 7000's thats not the "greatest"
Hence why im RB26, aiming for 330rwkw but rather than 4500rpm, it'll be more like 3500rpm, with a MUCH broader span of power, with 240rwkw in before 3000rpm (where rb25 was more like 150rwkw) based on results of other cars with a setup similar to me
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1945579
Turbo's aside...
Have you considered using an RB30 bottom end?
If I ever had to rebuild my engine, I'd seriously contemplate going that way as the RB30 bottom end should definately give a much broader power band than the RB25. Add in a GT30 or GT35 turbo (with the usual supporting mods) and 320rwkw should be a formality. The bonus being that the power is usuable over a large part of the rev range as opposed to having peak power at the top of the rev range and not much else for the rest of it if you had the same power with the RB25.
https://www.sau.com.au/forums/topic/105432-upgrading-turbo/#findComment-1946895
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
