I have of late been considering letting the GTR go as I would like to use the money for other purposes.
I have owned the car for over 2 years and have been in the process of building it up almost the entire time. Most work was performed throughout last year and all the work completed by Gavin Wood, Autotech Labrador. Including full rebuild.
The work currently carried out to the car includes:-
(All parts bought NEW unless specified)
Genuine Nissan N1 Block ($3,500)
GTR Crank (replaced)
Adjustable Cam Gears
Apexi Power FC 'Plug N Play'
Apexi Electronic Boost Controller Kit
Apexi FC Commander Hand Controller
Apexi Super Intake kit for 80mm AFM's
Apexi GT Spec Intercooler (no longer in production) 136mm Thick
R33 Gtst 80mm AFM's <Used
Greddy/Trust Oil Catch Can
Greddy/Trust Intercooler Piping Kit
CP Forged Pistons
Tomei Metal Head Gasket
NISMO Fuel Pump
600cc injectors
HKS GT-SS Sports Turbines - Ball Bearing 320hp each
HKS Split Dump Pipes
HKS stage 2 cams and springs
Twin 3" Front Pipes into single 3.5" Exhaust. N1 Style Muffler
N1 Oil pump
N1 Water Pump
OS Giken Triple Plate Clutch R3C
Lightened Flywheel
Apline MP3 Headunit w/remote
Alarm System with Remote Central Locking
Bride Reclining Racing Seats w/genuine rails
Nismo Duracon Gearknob
TEIN Super Street Coilovers (adjusted for Australian Conditions)
(Height and Dampening Adjustable)
Front Strut Brace
Michelin Pilot Preceda Tyres
Slotted Brake Rotors and Bendix Pads
Price: $32,000 $29,000 $28,500 No RWC, No Offers 50% OFF BUILD PRICE!!1!!1 I added up $20,000 in parts alone in my head over the past 2 years.
At present the car is only producing 350awhp @ 1.2bar, If I keep the car and add larger injectors and Pon Cams I can achieve alot more. Everything else is in place including the major labour costs.
Contact: [email protected]
Edited by 600ZILLA
350awkw with a couple more minor mods :rolleyes: Most people would know the capabilities of the GT-SS Turbos by now.
I tidied up the original post and adjusted the price to better meet the current market.
Jonathan
Edited by 600ZILLA
I will consider part trades such as R32 Gtst, 180SX, Silvia up to around $12,000.
Edit: I should also mention I take very good care of my gear, the car is always under cover and clean throughout. Generally only taken out on weekends.
Around 15,000km since rebuild and most of which was running in and low boost.
Edited by 600ZILLA
Thanks for the comments guys. My situation has changed a bit and have decided to amend the price.
Price drop $30,000 FIRM.
Edited by 600ZILLA
Thanks for the positive comments fella's.
The car is a pleasure to drive, I borrowed my mums commodore the other day and I soon remembered just how good it is.
Jonathan
From the look of the photos and the list of work performed, this is one of the best modded 32 gtr's for sale at the moment. If I had the money, I'd be making an offer, $30k is not unreasonable. Good luck mate.
Added to Carsales for $31,000 inc. RWC.
The price $30,000 is without RWC
Otherwise i can remove parts for a cheaper price but would prefer not to do this considering its a couple mods from 360awkw.
Jonathan
The car requires Pon Cams or similar and larger injectors so around $1400 in parts, some tuning and a bit of labour. I may do this work shortly and bump the sale price a bit.
The difference in price for RWC is because I would need to changeover a couple parts to meet RWC, exhaust possibly and change back over again.
I am also doing contract work and a few hours away from work adds up quickly.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
