Front Pipe + Dump Pipe (Before/After Dyno Results) - 203rwkw Stock ECU/Turbo
Okay guys as promised here are the before/after results of some cheap maintenance + the different between a cat-back and a full exhaust. The graph is shown at the bottom.
Spec's:
BEFORE - Green line on the graph
1995 GTS-T Series II
FMIC (Micks Metalcrafts)
2 Stage Boost Controller (7/12 psi)
HKS Pod filter
3" Nismo cat-back
Stock ECU
Stock Turbo
96 RON Fuel
Motul Turbo Oil done 8,000km (Ouch!)
Results:
7psi = 168 rwkw
12psi = 192 rwkw
AFTER (3mths later) - Red line on the graph
HKS Pod filter
3" Nismo cat-back
Stock ECU
Stock Turbo
* 3" Custom 1 piece Front+Dump Pipe
* 3" Custom Hiflowed Cat
* 98 RON Fuel
* New Ryco Oil Filter
* New Ryco Fuel Filter
* Castrol Magnatec Oil done 2,000km
(Car has not been serviced by a mechanic for atleast 15,000km, Just been doing fluid changes and sheee purrrs)
Results:
7psi = 185 rwkw (Up 17rwkw)
12psi = 203 rwkw (Up 11rwkw)
Conclusion
Well as you can see some cheap maintenance and a proper full exhaust system can make quite abit of difference. The midrange power in my car is 500% better now that I have a proper full 3" exhaust. Some of the benefits I (as a driver) noticed after fitting the exhaust:
* Heaps better midrange power it almost feels like the Turbo is cutting in earlier
* Much more free flowing when you back off the gas it literally just rolls for ever, none of the sudden jerky-ness it just keels going
* No difference in the note/sound of the exhaust from the inside the car
I don't know how my car drove with just the stock standard Nissan exhaust as the previous owner had already fitted the 3" Nismo Cat-Back, but basically from a novice drivers point of view your exhaust is only as good as the weakest link and if you only have a standard front + dump pipe your absolutely kidding yourself. Go and spend the extra $750 like I did and you'll love it to bits.
I have no idea if the ECU has been re-mapped or has an addon-card. I've taken the kick panel off and everything appears to be stock, oem nissan stamp, no extra doobie-whackys etc. If you see me out and about ask me if you can see my ECU as no doubt you'll know what your looking for to work out if its stock or not coz I really have no idea.
I'm gonna keep throwing small amounts of money at this car (when I workout a new bank I can rob that isn't local) but keeping the Stock Turbo + ECU and really see what I can get out of it. Their have been HEAPS of people say that 200rwkw isn't possible from a stock ECU/Turbo well im going to get more out of this bitch you just watch me. (Hoping 210+)
I plan on changing the HKS Pod to an Apexi filter and also install the f/glass box I have and create an airduct from down on my front bar to feed the engine some much needed cold air. Maybe also 1 of those oil catch can thingy's and urmmm well I dunno i'll keep reading SAU to workout what else can be done.
If you have any suggestions throw em hear as i'd love to hear your comments.
Ben.
[MOVEIT]
  • Replies 84
nice work dude :)
now that u mentioned it...i was wondering why my friends camry still glided off throttle and my 180 slowed down so fast....
time to change the rest of the exhaust system methinks ;)
interesting how fuel leaned out after dump+front without touching the ecu....
Congrats Ben
Watched your runs and reckon you should check your rears for flat spots as I saw rubber shooting off when the tyres came back onto the back rollers.
OK........ You asked me to post my result.
You must remember that I have a stock R33 with only a bleed type boost controller set, after my first run, at 10lbs (first run was pinging).
Ended up with 148.8, pretty happy with that (Wife is chuffed).
I think that you may have silenced some critics with your results, if your car has stock ECU etc.
Will watch your progress from here on.
What is the next step? ...... Anybody?
Yup same Dyno, same guys, exactly the same style runs. (www.unigroup.com.au - Excelent bunch of guys who really know their stuff)
First time was an SAU day with around 25 Skylines
Second time (Saturday) was with the Silvia guys and once again about 25+ cars.
Try installing a thermo Fan Ben,
Iv heard (so don't shoot me) but installing a thermo fan COULD increase power by 10%, we you will not have another belt running off the engine, thus less strain on engine more power @ wheels :)
Donnie
Yup thats what I was actually thinking after reading 2 or 3 threads on here and also reading over rev210's "12sec how to" thread.
If anybody can pass on some exact links, prices, before/after results etc etc it would be greatful.
Benm,
I put a thermo fan on mine about 2 weeks ago.
I picked up a second hand Davies Craig 16 inch fan for $150, and bought the thermo switch for $70.
Couldn't use the standard fan shroud cause it sits too high, and had to do a very slight mod to the fan to get it too fit.
It's a damn tight fit. The fan only JUST fit's height wise.
Over all the engine rev's easier. I wouldn't say it has more power, but it does rev easier. I 'think' this is sort of the same effect you'd get if you had a light weight flywheel, but not as dramatic (light weight fly wheel would be heaps more effect on the revs).
The temp does run a tad warmer now, but is very stable. Plus the car warms up HEAPS faster which is great for those cold mornings.
A big plus is that the engine is soooooo much quieter now.
The only down side I have noticed is when the fan is on it's damn loud. The 16 inch Davies Craig fan pumps out 2200 CFM of air which is heaps..
J
I wouldn't have thought that the removal of the standard fan and replacing with a thermo fan would have had much effect on the driveability of the car?
The fan is a viscous one so spins even if the engine is off. Those old fans on old cars that are driven by the crank would sap power but I thought viscous ones didn't :confused:
I'm probably wrong though :)
Benm, looking at your AF ratios, there is no way that is a stock ecu, either that or nissan really stuffed up 'cos OEM runs REALLY rich, even power fc when reset runs richer than that. when I had mine dynoed, it just ran straight off the bottom of the chart.
If you want 210rwkw, just up the boost to 1bar..lol
Jimih, anything that is driven by the engine will sap power to some degree or another.
I think steve has pointed out the missing link, the AFR's...
It does seem quite rich for a 'stock ECU'...
Should open up the ECU ben...
thats what i was gonna say, with my s-afc i cant even get the a/f ratios to stay so even on 12.1 when on boost like your car benm.
With stock ecu u would be getting 10.0 a/f ratios on boost!
Sure is mate and im hunting you down to get this 12sec pass. (As you have noticed in other threads). Which is why im watching your mods closely to see what I can do apart from just chucking on a bigger turbo.
I must say that moveit took my vote for best car on the day. Was immaculately presented and it made the power where others were carrying on. A very light ping was detected on the 2nd run but was nothing unusual in the 37 degree heat. When I was loading it up on the dyno before ramping it, it was pumping up to 6psi at only 2220rpm/full throttle in 4th gear. Top stuff compared to some of the monster turbo cars on the day.
Bigger turbo chargers will make more power higher up but the stock unit is impossible to beat on response and mid range puff.
I like it ;)
Originally posted by EnricoPalazzo
Man wats up with ur ECU
your car is a freak
Congrats!! : )
I've said it before and I'll say it again.
I swear the 1995 ECU's are different, but I'll check when I get mine done.... One day.....
JiMiH - I wouldn't say the difference was massive, but it was noticable.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
