Front Pipe + Dump Pipe (Before/After Dyno Results) - 203rwkw Stock ECU/Turbo
rev,
Where are you getting the knock sensor read out?
Doesn't the ECU ignore the knock sensor above a certain rpm?
(exact rpm cut off is load dependant)
Originally posted by rev210
I said before somewhere else there might be a little more (5-10HP maybe) I might get out for the dyno time. Dyno time is expensive and tuning the S-afc is pretty easy with the knock sensor read out.
  • Replies 84
Tuning 'properly' does not necessarilly = dyno.
I agree with that....a light tune (20mins on the road) and I could feel the difference....I prefer response moreso than top end power, esp since it's my daily driver :)
Originally posted by SlowGTS-t
I'd be worried about how the A/F ratio gets leaner with more boost, I'd say that the injectors are pretty much maxed out or something.
12.0:1 is a bit on the lean side for a daily driver...
12.0 is fine or a daily driver if u use 98 RON!
on stock fuel pump and injectors with a s-afc u need to have the setting - 12% or so to get that a/f ratio, so theres plenty left in the fuel pump and injectors
Hi guys, let me work this out....
Benm's car was 203 rwkw, that's about 270 rwhp, which is around 350 bhp (260 kw).
Compared to a standard R33 GTST which is 135 rwkw, that's about 180 rwhp, which is around 250 bhp (185 kw). Close enough.
So an extra 5 lbs of boost (7 to 12), a FMIC, pod and a full exhaust made an extra 90 rwhp (68 rwkw). Better still, at standard boost, the FMIC, exhaust and pod made 67 rwhp (50 rwkw).
And the A/F ratios sit between 11.8 and 12.2 to 1 from 5,000 rpm to 7,000 rpm. It would take me a couple of hours on the dyno with the PFC to get them that great.
That's a pretty damn good result I'd say, gotta get me one of those '95 model ECU's.
Have to agree with Rev here - after sticking in a S-AFC and spending about half an hour looking like a #$%^head on the freeway and other main(ish) roads, you can tune these things pretty darn well.
A very noticeable difference, but mostly more "driveable" power, which when you face it is what most of us really want. squeezing those extra few kW while wringing its neck at 7000rpm is all well and good, but i think you can get a decent result without jumping on the dyno.
p.s. i want that ECU!!
/me waits for the slashing to start
23710-21U60
MEC-K620
A2-5322
(Click here to see a pic)
Sorry about the quality I dont know how to use my camera yet (Geeze c'mon i've only had it for 6mths)
:uh-huh:
Originally posted by benm
23710-21U60
MEC-K620
A2-5322
I think that'd be a R620, not a K620. Fuzzy pic ;)
Here's a link to all the ECU types. You'll have to dump the URL into Babelfish to do the translations though :)
http://www.grid.co.jp/prod/rom/map.htm
http://babelfish.altavista.com/babelfish/tr
I 'think' they are listed in date order and order of manufacture??
And another link for other ECU's, with this one you'll have to jump between babelfish and normal cause it stuffs up the formating....
http://www.grid.co.jp/DAT/unitdat.txt
I suppose we won't really know what's going on with the ECU's until we do a direct comparison on the same car :)
J
Originally posted by ed
how often do you get up to 6 grand on a daily driver?
heheheh Daily of course :)
I guess what I'm saying is that running that lean doesnt give much allowance for things like bad fuel, blocked fuel filters, anything else, maybe even hot days.
Question. Should a car run leaner if you put more boost on?
comparing your dyno figures will be a waste of time unless everyone's is run on shootout mode! my mates 300tt made just over 200rwkw on shootout mode then a couple of months later put C.E.S 3" twin dump pipes on it (still had std front just cat back setup) & only made 209rwkw on the normal tuning mode! From what i have seen of the shootout mode it is abit generous!
I can't really see the argument your making here ?
Same Dyno
Same Tuners
Same Mode
Very similar day (temperature)
This thread was to compare the before/after of fitting a frontpipe so i think its totally fine regardless of whether it was in shootout mode or not.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
