Front Pipe + Dump Pipe (Before/After Dyno Results) - 203rwkw Stock ECU/Turbo
rev,
Where are you getting the knock sensor read out?
Doesn't the ECU ignore the knock sensor above a certain rpm?
(exact rpm cut off is load dependant)
Originally posted by rev210
I said before somewhere else there might be a little more (5-10HP maybe) I might get out for the dyno time. Dyno time is expensive and tuning the S-afc is pretty easy with the knock sensor read out.
  • Replies 84
Tuning 'properly' does not necessarilly = dyno.
I agree with that....a light tune (20mins on the road) and I could feel the difference....I prefer response moreso than top end power, esp since it's my daily driver :)
Originally posted by SlowGTS-t
I'd be worried about how the A/F ratio gets leaner with more boost, I'd say that the injectors are pretty much maxed out or something.
12.0:1 is a bit on the lean side for a daily driver...
12.0 is fine or a daily driver if u use 98 RON!
on stock fuel pump and injectors with a s-afc u need to have the setting - 12% or so to get that a/f ratio, so theres plenty left in the fuel pump and injectors
Hi guys, let me work this out....
Benm's car was 203 rwkw, that's about 270 rwhp, which is around 350 bhp (260 kw).
Compared to a standard R33 GTST which is 135 rwkw, that's about 180 rwhp, which is around 250 bhp (185 kw). Close enough.
So an extra 5 lbs of boost (7 to 12), a FMIC, pod and a full exhaust made an extra 90 rwhp (68 rwkw). Better still, at standard boost, the FMIC, exhaust and pod made 67 rwhp (50 rwkw).
And the A/F ratios sit between 11.8 and 12.2 to 1 from 5,000 rpm to 7,000 rpm. It would take me a couple of hours on the dyno with the PFC to get them that great.
That's a pretty damn good result I'd say, gotta get me one of those '95 model ECU's.
Have to agree with Rev here - after sticking in a S-AFC and spending about half an hour looking like a #$%^head on the freeway and other main(ish) roads, you can tune these things pretty darn well.
A very noticeable difference, but mostly more "driveable" power, which when you face it is what most of us really want. squeezing those extra few kW while wringing its neck at 7000rpm is all well and good, but i think you can get a decent result without jumping on the dyno.
p.s. i want that ECU!!
/me waits for the slashing to start
23710-21U60
MEC-K620
A2-5322
(Click here to see a pic)
Sorry about the quality I dont know how to use my camera yet (Geeze c'mon i've only had it for 6mths)
:uh-huh:
Originally posted by benm
23710-21U60
MEC-K620
A2-5322
I think that'd be a R620, not a K620. Fuzzy pic ;)
Here's a link to all the ECU types. You'll have to dump the URL into Babelfish to do the translations though :)
http://www.grid.co.jp/prod/rom/map.htm
http://babelfish.altavista.com/babelfish/tr
I 'think' they are listed in date order and order of manufacture??
And another link for other ECU's, with this one you'll have to jump between babelfish and normal cause it stuffs up the formating....
http://www.grid.co.jp/DAT/unitdat.txt
I suppose we won't really know what's going on with the ECU's until we do a direct comparison on the same car :)
J
Originally posted by ed
how often do you get up to 6 grand on a daily driver?
heheheh Daily of course :)
I guess what I'm saying is that running that lean doesnt give much allowance for things like bad fuel, blocked fuel filters, anything else, maybe even hot days.
Question. Should a car run leaner if you put more boost on?
comparing your dyno figures will be a waste of time unless everyone's is run on shootout mode! my mates 300tt made just over 200rwkw on shootout mode then a couple of months later put C.E.S 3" twin dump pipes on it (still had std front just cat back setup) & only made 209rwkw on the normal tuning mode! From what i have seen of the shootout mode it is abit generous!
I can't really see the argument your making here ?
Same Dyno
Same Tuners
Same Mode
Very similar day (temperature)
This thread was to compare the before/after of fitting a frontpipe so i think its totally fine regardless of whether it was in shootout mode or not.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
