brilliant weekend
terry ashwood in car number 8 (usually 33) picked up 1st place ion all three races
he was up against [peter brock in a pretty nuts A9X
well done to terry ashwood who won all 3 races at historic vehicles meet in p.i. this past weekend
beating peter brock in an A9X in all three races
terry ashwood is now 4 seconds off jim richard's time of 1:41 in the same car on p.i.
look who is top on each of the results lists
a great weekend
hr31s next racing at eastern creek next month apparently
fred gibson was there on the saturday. 31gun says he has some VERY interesting stories to tell. for example, they had skaifey driving an auto gxe with a big turbo slapped on it around the streets in melbourne back when they were doing testing.
anyway go the thirty two!!
cheers, MARK
  • Replies 95
Love it !!! :(
So did Terry actually get some good starts or do the bog-down & catch-up thing again ?
Poor Brocky, he must really be getting tired of seeing those Skyline tail lights after all these years :P
BTW, Top pic of Rod's car !!!
And one of the GTRs . this is for cars up and including 92 or before 92? And when were the 32s out 92 wasnt it.
32 GTRs were racing (and winning) in the ATCC in 1991.
32's were winning in late 1990!
Hooks
I thought in the first few races that the R32 and the R31 were in together on australian soil (the changeover period), the R32 got beat by the 31's?
Yeh Jim Richards actually win the 1990 SATCC in the R31 GTSR. Mid season Skaife started running the GTR at rounds getting it ready for Bathurst and the 91 season. I think the GTRs first round was Winton in 1990, adn the GTS-Rs last rounbd was Oran Park with Jim behind the wheel wrapping up the championship..
Can anyone remember what the R31 GTSR came at Bathurst in 1990? Or did Gibson just run the single GTR? I seem to recall in 89 the R31s came 2nd and 3rd at Bathurst behind the Shell Sierra.
