It has been discussed somewhat in old posts, but I would like to get some recent feedback on syncro gearbox options for street driven GT-Rs. I'm NOT interested in going to dog engagement gears, so I figure that leaves:
1. Replace/rebuild standard gearbox as required. I guess that this is the most common practice as it works out cheapest. Reliability will obviously depend on factors such as abuse, main duty of car (drag racing etc) and torque.
2. OSG helical gearset with syncros. These would appear (to me anyway) to be basically the same size and design as OEM Nissan gears, with the benefit being that they (theoretically) are manufactured with higher strength due to their metallurgy and finishing.
3. PAR straight cut gearset with syncros. If you believe PAR's caim on their website, the large tooth profile means that there is added strength and reliability in going to this straight cut profile. The downside is the noise, however in theory this should only be in 1st, 2nd and 3rd gears (4th is 1:1 ratio and 5th will retain standard helical gears).
I would appreciate feedback on the OSG and PAR options from people who have tried the products. Any premature or unexpected failures?
Cheers
Gav
https://www.sau.com.au/forums/topic/105996-gtr-gearset-options/
ppg also make a synchro GTR box i think. most people i know who have used both, favour there product over the PAR ones.
from what i know the other difference the OS box has over stock is the tooth pitch is different. slightly 'straighter' profile so there is a little more gear noise than stock. i have one in my car, but only running around 250rwkw so as expected no failures or problems. i can say it's not as easy to shift when shifting slowly at low engine speed as a stock box, but at high RPM with faster shifts it is beatiful to use. i'm also running a OS solid centre twin plate, which may be half of the driveability problem, but it is not that bad (the box i mean).
i reckon someone in w.a should start selling some cheap gearsets and they would be millionaires :P or even second hand gtr boxes as they will be breaking like twigs between u, simon, bobbo, mine and a couple of other high power 26's haha :P
Edited by CruiseLiner
Auto Gallery Yokohama make a double syncro coned gearset...
http://www.ag-y.com/english.htm
I think Auto Gallery yokohama just do a double syncro conversion. They also upgrade gearsets...but I'm pretty sure they use OS Giken gear sets.
One think with the Giken gearset is that 1st is so damn tall. It would be a pain for hill starts and driving up driveways, especially in a heavy R33/R34/Stag with biggish cams.
The size and tooth profile of the OS gerset is vastly different from the Nissan design.....big thick chunky teeth.
Im leaning towards the PAR, simply for value for money reasons. It looks like a very strong box, and they guarantee it up to 750bhp. It costs less than $5000 for them to rebuild the box with new gearset and a freshen up of the box (new bearings etc).
Have seen one installed in a GTR, the owner said driving it was very similar to the stock box. The only real downfall is they are -very- noisy 1st through 3rd.
Amaru: OS Giken 5 Speed Gear Set all the way for me, I know of PAR and Sam the owner and im not a fan of his designs or buisness sense.
NissanFreak
Haha...I was going to post something along those lines, but you beat me to it.
Strange how he doesn't put his name to his gear anymore...
Oops - my bad, shows that it's dangerous to assume! I would be keen to see a set of OEM gears next to the OSG set.
With regards to the OSG set, I remember Mario basically writing them off as a waste of time (actually sh!te was the term he used I think), but I guess it depends on what the ultimate use is and how they're "abused"
il second that. my little ts2bd clutch is feeling the strain. just like taking of in second :)
nice con rods too. all the meat in the right place. did he tell you no one here buys his stuff. and that it all goes to the states? :lol:
I have a PAR gearset in my S15.The standard set didnt like 250rwkw much.So far no problems,feels strong,a bit noisier,drives like standard.Cost me $4800 all up with delivery to NSW and back,with them rebuilding the box.
I think I'll be using the OS set for my GTR though.
Sam doesnt return calls but he does reply to emails.
Anyone used his rods on a GTR???
Here's a picture of the OS Giken Gear Set. As far PAR rods one comment "they are way too heavy, anyone can build a strong rod if they dont take weight into account" and because of this PAR rods in a high rpm RB26 it would put extra load on the bearings etc.
And my engine builder also said that he once ordered a set and one rod was 1mm shorter than the other three, had him dumb founded on dummy assembly why his squish was out on one cylinder LOL.
Anyway as people may have guessed I am not a big PAR fan.
NissanFreak
Edited by NissanFreak
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
