friend i am taking is female...
and you can abbreviate roger to "rodge"
drove past "SIR32" today! :laugh: u were near coolum on the coast road. i was in the falcon work ute, so u wouldnt have recogniced me anyway..... did u end up going up to noosa did u??? was a good day for it.
  • Replies 461
yeah, 'twas me...
just went for a drive all the way up the coast road from mooloolaba to noosa... decided noosa was too touristy and crowded when we got there, so we went back to the surf club at mooloolaba for lunch.
got their "Seafood Platter, Hot & Cold, for 2"... tell ya what, there's not alot on them :D
Also, the oysters were crap :)
With unleaded sitting at $1.28/L as of last night (which puts Optimax close to $1.40/L), I don't know how anyone can afford to cruise at the moment... :laugh:
I deduct what I can come tax time, cruising I like to call cliental relationship building, that or “prospecting” for new cliental hahah.
You should have complained...
My mum works in the kitchen. I'll have some words with her :laugh:
Edited by Drift_Limo
Hey guys, any of you see a stockish looking white r33 with white avs rims and a zorst cruising around it will most likely be mine.
I bought it from the gold coast just over a week ago and havnt really been driving it around yet.
im still getting over the cost of running a turbo car.
going from $40 for 600ks in the pulsar to $80 for 450 in the 33 is a shock.
anyways if anyone see's me give me a wave. i work in brisbane during the week with energex and am only home on the weekends at the moment.
Edited by hayden49
Hey guys,
went for my first cruise in my new 33 today. At m'bah on the sunny coast there were a few good cars out as well as a healthy dose of nissan imports.
there was a pink silvia and dark colourd 180 i gave a nod to, belong to anyone on here?
all in all good arvo. :(
i was the guy in the white 2dr r33 with white avs rims.
yeah fuel prices mostly, but also been too busy since quitting my job... how ironic! (not that I ever bumped into anyone when I was out anyway!)
...also trying to decide whether I should upgrade the R33 NA bodykit before upgrading to a R34 GTT... hmmm.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
